Battery drain
Old Feb 27, 2017 | 04:57 PM
Billdusang's Avatar
Billdusang
1st Gear
Default Battery drain
I can't find the power draw. Removed each fuse, each relay changed the main headlight relay( front right fender 300.00.) removed the wires at turn signal/ light switch. Still the power drain continues. About 2 amps. Is the head light control always hot? I can hear it click when battery is connected. Help!
Old Feb 27, 2017 | 08:14 PM
S.McDonald's Avatar
S.McDonald
Have you checked power draw after 20 or so minutes. It takes a while for systems to shut down. Mine dropped to around .2 amps after around 20 minutes.
