HVAC question
Old Mar 1, 2017 | 12:16 PM
lucky99's Avatar
lucky99
Default HVAC question
Air blows cold on driver side hot on passengers side. I can pull the fuse and sync them up but when it sets for a few days goes back blowing cold on drivers side.
Old Mar 1, 2017 | 12:38 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Sounds like one of the actuators is damaged. Pull the DTCs and post what the HVAC Module has for DTCs.. That will tell you what actuator is not working correctly:
READING YOUR Engine Diagnostic Codes
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine. NOTE! You can read the DTCs with the engine running and or driving down the road but it can distract you. BE careful! Some DTCs clear themselves when you turn the ignition OFF!
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold OPTIONS
4) While holding OPTIONS, press FUEL four times within a 10-second period.
Initially, on-board diagnostics go into an Automatic Mode which shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two kinds of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current C code indicates a malfunction is present and active in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes.
More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except English/Metric (E/M). Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press and hold the RESET button To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5. You can GOOGLE the DTC and also find information on it.
Here is very good site that explains the DTCs:
http://www.corvette-web-central.com/C5DTCcode.html
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix!!
Old Mar 1, 2017 | 04:02 PM
rrwirsi's Avatar
rrwirsi
For the 2+ years I have HVAC codes when I did the code search while the car was running. I did all the passive repairs suggestions on the forum and nothing helped to remove the codes. Honestly, I did not notice any issues between the drivers and passengers vents even though I had the codes saying there was an issue. So several months ago I read a post on another issue involving the HVAC that suggested switching the outside air mode to inside. I did and amazingly, no longer did I get the code issues. Just thought I would pass my experience along.
Old Mar 3, 2017 | 09:00 AM
lucky99's Avatar
lucky99
It shows 0361 and 0363 both are H codes. My next question is what are the best blend doors to replace them with. It looks as if the OEM have a lot of issues. If I have to pull the dash I am going to replace them both.
Old Mar 3, 2017 | 12:57 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
BLEND DOORS??????????????? You need to be replacing the ACTUATORS. There are two kinds. DUAL ZONE Actuators and one for the Manual operated air box.
Get the ones specifically for your system.
Old Mar 3, 2017 | 04:19 PM
lucky99's Avatar
lucky99
Yes sir my bad. I guess I should have asked the best brand of actuators. Yes I have dual climate control
To HVAC question
