Cruise Control Issue
Old Mar 2, 2017 | 10:36 AM
68 Big Block's Avatar
68 Big Block
Default Cruise Control Issue
Hi all,
I just bought a 2002 C5, and I have the following problem. Occasionally, the cruise control will disengage for no apparent reason with the Active Handling turned on. If I turn off the Active Handling, it doesn't do it. I read the forum and saw the info on grounds and disconnected the battery to clean all of the grounds before I did anything else, and it didn't fix the problem. (The grounds all appeared to be very clean) Next, I checked the codes, and I have the following:
28-TCS -
C 1214 H
C 1287 H
AO-LDCM
B 2252 H
B 2282 H
B 2284 H
U 1064 H
A1 RDCM
B 2283 H
B 2285 H
U 1064 H
I didn't check the codes before I disconnected the battery so I'm not sure if any of the codes were caused by disconnecting the battery or not. Should I clear the codes and start again, or is there something in the codes that is a "smoking gun"?
Thanks in advance. This forum is invaluable for us C5 newbies.
Regards,
Merle
Old Mar 2, 2017 | 10:57 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The very first thing that I would do is check the CLUTCH & BRAKE Peddle switch. If they are not in proper adjustment, any BUMP can cause them to tell the EBTCM that you applied the BRAKE and or pressed the clutch (if you have one) and that disengages the cruise.
When you experience the issue, WITHOUT turning off the ignition, read the DTCs using the DIC. If you have DIC messages, just press RESET until they clear and then read the DTCs
CLEAR all that previous info and start with a clear slate.
The C1214 DTC tells us that you need to have the EBTCM internal power relay replaced. Replace it or send the module to one of the ABS Fixer people.
If you really have a 1214 issue, it will sooner or later prevent the module from even working.
Bill
Old Mar 2, 2017 | 06:47 PM
68 Big Block
Thanks to both of you for the info. This forum, and guys like you both, are invaluable.
Originally Posted by 8VETTE7
Check out the switches mentioned and clear the codes and then drive the car to see what codes return.. Those codes that return are the ones that need attention.
The LDCM and RDCM codes you posted are from a recent battery related event. Either the battery went low or perhaps was disconnected/reconnected and caused those codes.
The C1214 would be the first thing to work on. It may be responsible for the C1287 (Steering Wheel Position Sensor) or there may be a separate issue with the SWPS being/going bad. Unfortunately EBCM and SWPS issues are NOT uncommon on the C5.
Here is a link to a DIY thread about repairing the EBCM C1214 code if you are a DIY type person:
http://forums.corvetteforum.com/c5-t...r-fleabay.html
Old Mar 2, 2017 | 08:30 PM
coia96vette's Avatar
coia96vette
I also agree with the above. When you check the codes after clearing them I bet the C1287 will come back. That is the SWPS. The part # is 88965543. They still make them for the '01 and newer cars. I had the same thing happen to my '04.
Old Mar 2, 2017 | 10:59 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
There are a few things that will dis engage your cruise control----A misfire whether REAL or FALSE will make the CC dis engage--So will a fouled brake light circuit on an auto car or the clutch circuit on a manual car---Also on an auto car a misfire will also cause the converter to "UNLOCK" which again will make the CC dis engage---
Finally on an auto car the converter will not lock until the trans temp goes above apprx 140* which may cause the CC to act weird
On a stock engine this is rare However on engines that have major mods--these mods will create false misfires--The biggest culprit for false misfires are
1. LT headers ( sometimes even shorty hdrs)
2. After market camshafts
3. A higher than stock TQ converter
4.On a manual trans --a lightened flywheel or aftermarket clutch
5 stiff stronger nosier valve train ( springs or rocker arms)
any mod that creates "new different engine noises different from the stock engine noise
GOOD news is that all these nosies can be "tuned out" with proper tuning
Old Mar 10, 2017 | 10:32 AM
68 Big Block
Bill
So I cleared all the codes and drove the car. I drove about 40 miles to my son's house, and the cruise control disengaged 6 times, then when I drove 40 miles back home on the same road with the active handling turned off, it didn't disengage once. I then checked the codes again, and there were none. If the clutch and/or brake pedal switches were the culprit, why would turning off the active handling have any effect? Very confusing! BTW the car is 100% stock. I bought it off of the original owner, an 84 year old man who sold it because he had problems getting in/out of it. When I questioned him about it, naturally he said it never happened when he had it.
Regards, Merle
Old Mar 10, 2017 | 03:54 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If a Traction Control event or ACTIVE HANDLING EVENT caused the cruise to turn off, The TC or AH event would have been ACTIVE for short period of time. When any EBTCM Handling feature goes active, you should have see that event message come on breifly in the DIC Message Center. Next time it shuts off the cruise, glance down at the DIC and see if there are any messages displayed.
If an EBTCM ERROR causes the issue, that EBTCM DTC will be storred in EBTCM Memory with in that ignition cycle.
If you read the DTCs (WITHOUT) turning off the ignition, (shortly after the cruise turns off) you should be able to pull up ANY DTC that the EBTCM is complaining about.
If there are no storred DTC,,,,,,,, ,,,,,,,,,,,,, I will have to dig a LOT deeper to try to figure it out.
BC
Old Mar 10, 2017 | 05:44 PM
coia96vette
Also it can take awhile for the codes for the SWPS to show up. On my '04 about a week. Finally the C1287 and /or C1288 did show and has been fine since replacing it.
Old Mar 10, 2017 | 10:57 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
My 01 MN6 was disengaging the cruise about every time I got it warmed up and in 6th.
I changed plugs and wires as part of regular maintenance, and come to think of it, it hasn't done it since
Another thing I did was warm it up in the garage for an extra few seconds while I put my seat belt on and adjusted the wheel. haven't done that in a while either.
Hasn't done it since. I bought the steering wheel position sensor, but it hasn't done it in a long time now, so not sure if I have to change it.
I am amazed at this car. I haven't done much to maintain it, and it just starts and goes.
80,000 miles and just little things.
Old Mar 11, 2017 | 08:01 AM
Emil C5's Avatar
Emil C5
I had the same problem years ago, dealer replaced a sensor in the steering and it solved it. Unfortunately I cannot find the invoice with the exact sensor but the symptoms were exactly like yours. Good luck.
Old Mar 11, 2017 | 01:50 PM
68 Big Block
Thanks to all for the input, I will let you know what I find the next timeI have the car out (crappy weather in Ohio right now)
Regards,
Merle
Old Mar 30, 2017 | 10:07 AM
68 Big Block
BC
So I drove the car yesterday with the Active Handling turned on, and again the cruise control disengaged . I immediately looked down at the DIC and it said "Active Handling" then "Cruise Disengaged". Then I pulled into a gas station and checked the codes without shutting off the car, and 1 code, "C 1287 H C" showed up in the TCS module. So I'm assuming it is the SWPS that is at fault, correct?
Secondly, is it likely that replacing the SWPS will cure the problem?
Old Mar 31, 2017 | 10:53 AM
coia96vette
Yes that is the SWPS. Replacing it will solve your problem. At least it did on my '04. Part# is 88965543 and they cost about $70. Takes about 2.5 to 3 hours to do.
To Cruise Control Issue
