Slight, rhythmic vibration
Old Mar 9, 2017 | 01:43 PM
billvh's Avatar
billvh
Default Slight, rhythmic vibration
I have a slight vibration at highway speeds that seems to have a kind of pattern. It is smooth, then shimmies slightly in a rhythmic pattern. Have all new tires, and have been re balanced. Could the torque tube cause this?
Old Mar 9, 2017 | 08:00 PM
FL Skydiver's Avatar
FL Skydiver
I have the same thing, not sure what it is. New tires also, balanced and aligned.
Old Mar 9, 2017 | 09:29 PM
namvet6869's Avatar
namvet6869
Having same issue on my 2000.
Old Mar 10, 2017 | 04:52 PM
3sACROWD's Avatar
3sACROWD
Any chance you're running the AC? Maybe the condenser or alternator cycling? Is it speed or RPM sensitive?
Old Mar 10, 2017 | 05:31 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Yes !!
Old Mar 10, 2017 | 06:04 PM
dankhts's Avatar
dankhts
Old Mar 11, 2017 | 12:42 PM
billvh's Avatar
billvh
No, just a very slight shimmy that comes and goes, in a pattern, with or without A/C. Had thought it was tires, had it balanced before, then got new tires, still does it.
Old Mar 11, 2017 | 12:43 PM
billvh's Avatar
billvh
Originally Posted by Pounder
Yes !!
Can it be balanced?
Old Mar 11, 2017 | 12:49 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
the couplers could be going bad ?? auto ?? manual ?? same in neutral ???
Old Mar 11, 2017 | 01:52 PM
billvh's Avatar
billvh
6 speed. Never tried putting it in neutral. Smooth most of the time, just slight vibration at highway speeds, not real bad. It's a drivetrain or wheel issue, not engine related at all.
Old Mar 13, 2017 | 06:35 PM
yngbld32's Avatar
yngbld32
Got the same thing also. Like your driving over a dull rumble strip every 15 sec or so?
Old Mar 13, 2017 | 07:41 PM
billvh's Avatar
billvh
Kind of, more like every 5 or 10 seconds, comes, goes, comes, goes etc.
I had magnesium wheels on it when I got it, can't remember if it did it then.
Old Mar 13, 2017 | 07:46 PM
onspeed's Avatar
onspeed
Have the same problem, TT couplers are good.
Old Mar 13, 2017 | 07:52 PM
billvh's Avatar
billvh
This is strange, seems like it's fairly common, but I haven't seen anything on it before.
Old Mar 13, 2017 | 09:04 PM
garebear's Avatar
garebear
"I have a slight vibration at highway speeds that seems to have a kind of pattern. It is smooth, then shimmies slightly in a rhythmic pattern. Have all new tires, and have been re balanced. Could the torque tube cause this?"
My 2002 vert does this also. Suggestions? (Automatic)...
Old Mar 14, 2017 | 12:17 PM
Roman 1's Avatar
Roman 1
This kind of sounds like a wheel bearing possibly. I had the same issue on my 2000 FRC. I tried balancing the wheels and no difference. Jacked the car up and checked the wheel bearings and found just a slight movement in the wheel on 3 of the 4 wheels. Replaced all four of the wheel bearings and the issue disappeared. My car had about 120k miles at the time.
Old Mar 14, 2017 | 12:52 PM
Roddy13's Avatar
Roddy13
Same thing here. I thought maybe rear end, tire related, fuel pump sound... or torque tube..
Old Mar 16, 2017 | 12:48 PM
Ronbo1786's Avatar
Ronbo1786
My 2000 Coupe does the same thing. New tires, rebalanced as well. Just been checking the forum to see possible causes to research.
Old Mar 17, 2017 | 02:08 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
BINGO!
That would be the first thing I would check. Jack up a wheel and give the wheel a PUSH PULL TEST at the 12:00/6:00 position and see if you can detect ANY slop/lost motion in the wheel HUB/Bearing assy. There should be little to NONE. Also, rotate the wheel and see if you can feel any roughness. With the load off the wheel bearing, that isn't always a good test but, I've seen some really bad ones that actually made noises.
The rear tires are more difficult to rotate but the push pull test works. You can also check the rear wheel hubs at the 09:00 & 03:00 positions.
To Slight, rhythmic vibration
