CA smog test help needed ASAP
Old Mar 12, 2017 | 07:02 PM
Caveboy's Avatar
Caveboy
Active Streak: 90 Days
Default CA smog test help needed ASAP
My 99 corvette is going thru the CA smog test. All the emissions passed but I am failing the readiness test status. The 2 tests I am failing are secondary air and oxygen heater readiness. Any help and suggestions appreciated. I reflagged the ECM 25 miles ago. Does it make a difference?
Old Mar 12, 2017 | 07:20 PM
Smoken1's Avatar
Smoken1
Yes it matters all the monitors need to be set. You need to go thru some drive cycles to reset them set, Most auto parts stores have a reader that can see if all are set
Old Mar 12, 2017 | 07:37 PM
Caveboy's Avatar
Caveboy
Hoping that is the case!
Old Mar 12, 2017 | 07:43 PM
RedRiderZR1's Avatar
RedRiderZR1
Check your codes, If there is an issue, it will show up in your codes. If no codes, than it will likely go READY after the required drive cycles.
Old Mar 12, 2017 | 08:26 PM
chain_5001's Avatar
chain_5001
Takes about 100 miles of driving for all the systems to be ready for smog. You can buy an obd scanner with the feature that reads the system readiness. When/if I do a repair before smog and reset the check engine light I usually drive it for at least 200 miles before taking it in.
Old Mar 12, 2017 | 08:34 PM
Caveboy's Avatar
Caveboy
Yes, I have a obd2 scanner hooked up to it and monitoring the readiness!
Old Mar 12, 2017 | 09:16 PM
Patches's Avatar
Patches
http://www.obdii.com/drivecycle.html
Old Mar 12, 2017 | 11:19 PM
SVT_Z06's Avatar
SVT_Z06
Not all codes need to be completed. You can have no more than one incomplete code.
Old Mar 12, 2017 | 11:30 PM
Caveboy's Avatar
Caveboy
Yes but I have 2 codes
Old Mar 13, 2017 | 12:30 AM
SVT_Z06's Avatar
SVT_Z06
Keep driving and check periodically.
To CA smog test help needed ASAP
