rocker panels
Door Opening Frame Replacement - Side
Tools Required
J 42058 Frame Adapter Clamp
Removal Procedure
Notice
The frame rails and bumper impact bars must be serviced as required, and returned to three-dimensional coordinates before any SMC repairs are attempted.
Visually inspect for damage to the frame rails or wheelhouse mounting areas. Restore as much of the damage as possible to specifications using three-dimensional measuring procedures. Use J 42058 if vehicle pulling and straightening are required.
Remove all panels and components to gain access to door side frame. The door side frame can be removed if the quarter panel is loosened from it. This may include removal of the following components:
Door
Quarter panel
Quarter inner splash shield
Remove latch striker closeout cover and striker.
Remove the trim screws that attach the side door frame panel to the rail. These screws must be re-installed to secure the service panel in place until the adhesive cures.
Important
Make sure the fuel inlet is sealed before proceeding with repair procedure.
Use caution along the underside of the vehicle when applying heat not to de-bond the floor panels from the frame rail.
Apply heat and pry to break bond along area (1).
Installation Procedure
Remove all remaining adhesive, and scuff all bonding surfaces to ensure proper adhesion.
Clean and prepare all bonding surfaces prior to SMC panel installation. Refer to Plastic Panels in Plastic Panel Information and Repair.
Prime all bare metal surfaces with PPGs DP90, or an equivalent epoxy anti-corrosion primer. Do not top-coat any bonding surface.
Temporarily fit the side door opening assembly to ensure proper fit and alignment with adjacent panels.
Remove panel assembly and apply a consistent bead of adhesive (1) to the front body hinge pillar and top surface of rail (2) and to all areas originally bonded, except for bottom side of rail.
The bead should be 10 mm (13/32 in) diameter.
This area is bonded after the side door opening assembly is installed.
Install assembly using original screws in factory locations. The screws are necessary to secure the service part until the adhesive cures.
Important
Ensure that the foam seal on the front body hinge pillar portion of the side door opening panel makes contact with the front hinge pillar.
Important
Use only approved adhesives. Refer to Repair Materials - Rigid Plastic Part in Plastic Panel Information and Repair.
Apply adhesive to inner edge of rocker and clamp in place until adhesive cures. Standoffs in part must fit flush against bottom of rail.
Remove excess adhesive squeeze-out and allow to cure.
Prime bare metal areas with PPGs DP90, or an equivalent epoxy anti-corrosion primer. Do not combine paint systems. Always refer to paint manufacturer's recommendations.
Install all related panels and components.
in regards to that. The rocker panels are glued onto the car and it is very difficult to get them off in one piece, and finding OEM replacements is very difficult. Perhaps one of the forum used parts vendors would have access to a complete rocker panel or at least one that can be spliced into the existing one to replace the damaged area. The latter is not the preferred way to go IMO, but it may be all that is available. Good luck settling this with the shop that did the damage and in getting the car repaired.
As Vetteman Jack mentioned the roof skin does not need to come off. The roof skin is separated from the rear quarter at the body seam and thus the rear quarter and lower rocker can be removed as assemblies without removing the roof. The biggest issue as he mentioned is going to be the rockers themselves. They never tend to come off as one piece and they're bonded in the same way that the front fender liners are bonded to the chassis. It's a very specific way the rockers have to go on when they're bonded, otherwise they will mess up visually how the door and rear quarter lines up with the body. It's a real PITA.
You're probably going to pay a good chunk for used replacements if you can get a set in one piece.
I'm not sure why you've pursued litigation against the shop unless your initial actions with them proved fruitless. If they are insured and claimed they weren't going to deal with you you probably should have went through your own insurance, who would have then went after them for the payout. I also would say it's probably a mistake you went to a Chevrolet dealer. What you should have done is contacted the dealer's service department and see who they authorize to service body work on Corvettes. All really big Chevrolet dealers, if they don't perform body work on-site, are required to have their utilized body shop have a Corvette-specific technician who is the only person that works on Corvettes. When I had some work on my car performed a few years back my local dealer referred me directly to the technician himself, whom I took the car to and had the damage accessed. He was a career body man (he started when C5s were still new) and having the experience knew exactly what to look for and how to handle it.
