O2 sensor issue
Old Mar 23, 2017 | 09:51 PM
Corvettez0601's Avatar
Corvettez0601
Default O2 sensor issue
i have replaced my O2 sensors (all 4) twice no and I'm still getting the same codes, anyone ever experience this before. I'd just ignore it but where I live has emissions testing so can't. Any help is greatly appreciated
Old Mar 24, 2017 | 06:35 AM
3sACROWD's Avatar
3sACROWD
It may not be your sensors. Maybe your catalytic converters are shot. What codes are you getting?
Old Mar 24, 2017 | 08:02 AM
foggy's Avatar
foggy
Need the Codes to Help You
Old Mar 24, 2017 | 08:22 AM
Corvettez0601
P0135
p0141
p0155
p0161
Old Mar 24, 2017 | 12:29 PM
feeder82's Avatar
feeder82
check the underhood fuse box, I think its number 15, o2 sensor heater fuse
Old Mar 30, 2017 | 08:39 AM
Corvettez0601
Replaced the fuse and still get the same codes
Old Mar 30, 2017 | 08:41 AM
Corvettez0601
Could it be a dirty maf?
Old Mar 30, 2017 | 09:12 AM
3sACROWD's Avatar
3sACROWD
Did you clear the codes then take the car for a drive? Clear the codes, take the care for a drive, then pull the codes BEFORE you turn the engine off. It is important to note if the codes have an H or HC or C after them. If they are all H only, you didn't clear them properly.
Old Mar 30, 2017 | 09:48 AM
Corvettez0601
Codes have been cleared and drove the car for almost 200 miles and the lights back on same damn codes
Corvettez0601
Shows them as C
Old Mar 30, 2017 | 11:05 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You MUST actually measure the heater voltage on the fuse. It must be full battery voltage. You also have to verify that you have a good chassis ground path. Disconnect the O2 connector and read the ground pin to chassis ground and check for proper resistance = zero...
Here is the H2SO (O2 sensor circuit)
You can purchase a scanner that reads live sensor data and actually track the O2 sensor output. It should constantly swing from high to low/low to high (200 mv to 800 mv) if its actually working correctly.
If it just hangs out around 450mv, its NOT working.
Bill
Old Mar 30, 2017 | 11:55 AM
3sACROWD's Avatar
3sACROWD
Bill
Bill, correct me if I'm wrong. The primary O2 sensors will vary more than the secondary sensors which will confirm the catalytic converters are working. If the values track the same, the cats are shot.
Old Mar 30, 2017 | 12:52 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
That would be a correct statement.
To O2 sensor issue
