Rapid blinker issue
Old Mar 24, 2017 | 01:01 PM
1320LS1's Avatar
1320LS1
Default Rapid blinker issue
My 2001 6 speed roadster with 82,000 miles has a rapid blinker issue.
It is only the left one, it seems to be about 3X as fast as normal.
The car has a history of electrical problems. Starters (3), steering column lock (multiple times), passenger door remote lock (3). I just replaced the hvac control unit less than 50 miles ago.
Is this a warning of bigger problems?
How do I correct it?
Thank you ahead of time for any and all assistance.
Old Mar 24, 2017 | 02:35 PM
unlvrebel's Avatar
unlvrebel
Start the car, turn the blinker on and see which one (front or back) doesn't work. Replace the bulb. All cars today are designed for a blinker to flash rapidly if one of the bulbs is out.
Old Mar 26, 2017 | 01:38 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Rapid blinking is most often caused by the use of LED tail lights or front turn signals
LED lights use very low amounts of amperage---and the stock mechanical flashers cannot work with that low of an amp useage-----The FIX is to install a DIGITAL or ELECTRONIC flasher unit----These will work as stock but with very low amp usage You can find them on line or at most any speed shop
To Rapid blinker issue
