More code ?
Old Sep 25, 2002 | 08:42 PM
knkayotte's Avatar
knkayotte
Default More code ?
P1416 AIR System Bank 2-B
U1016 Loss of Communication (LOC) with PCM
U1064 LOC DCM
U1096 LOC IPC
Does this mean I may have a bad sensor? Where do I find it? :(
Any help is appreciated
Later, Keith :flag
Old Sep 25, 2002 | 10:25 PM
knkayotte's Avatar
knkayotte
Default Re: More code ? (knkayotte)
TTT - Cleared the codes, went for a test drive, everything now seems okay. What the heck, should I be worried?
Later, Keith :flag
Old Sep 26, 2002 | 11:45 AM
jerryv's Avatar
jerryv
Generally, the 10xx codes are not considered too important unless they recur frequently. Most of us get them once in a while, and they all relate to loss of communication between modules.
Also, generally, it's safe to clear a history code ... but stay on the lookout in case it recurs. Most of the history codes will clear themselves in 40-50 ignition cycles, unless there's a recurrence.
If you're going to look at the codes and think/worry about them, you should invest in a service manual. Each DTC is described in some detail. Even if you don't do the service yourself, it's a great source of info, and at least lets you be informed if you have to take it to a dealer. Manuals are available from Ken Fichtner, direct from Helm (www.helminc.com) or you can sometimes find them on eBay.
Old Sep 26, 2002 | 04:28 PM
gojo's Avatar
gojo
http://www.obdii.com/codes.asp
Try this site for future reference.
To More code ?
