Problems after installing external LED bulbs
Old Apr 2, 2017 | 10:04 AM
v6turbo87's Avatar
v6turbo87
Default Problems after installing external LED bulbs
Having an issue on my 99 after installing external LED bulbs. First I DO HAVE a hyperflash harness installed. I started at the front of the car an put in the bulbs at each corner and tested the operation as I installed the bulbs. All worked fine until I had all the LED bulbs in. When I turn on the left blinker it works fine. If I turn on the right blinker all four of the blinkers flash, the rear side markers flash and the cluster back lights flash! If I put 2 stock regular bulbs in the right rear tail lights everything works fine. Here is another odd issue....if I have all the LED bulbs in and I press the LOCK on my fob the alarm goes off!!! If I put the 2 stock regular bulbs back in the right side the fob locks the car fine with no alarm. Admittedly I am using Ebay LED bulbs but I bought 4 taillamp bulbs from Superbight LEDS (made in Taiwan on the boxes) and had the same problem. Do I need to put in load resistors? I was under the impression with a hyperflash harness that load resistors were not needed? Anyone have any input on this?
Old Apr 2, 2017 | 11:09 AM
jcgunn's Avatar
jcgunn
I have LED switchbacks and a hyperflash harness and everything works great. When I tried LED brake lights, everything went crazy (like you describe). I went back to regular brake lights and all is well.
