So I own a 1997 C5...I'm replacing my front OEM shocks but my factory shocks have a plug in. I believe its for either soft ride or real time dampering. Either way I bought a set of Johnny O'connels that doesn't have the plug in... what can I do to bypass or fix this situation???
If you know someone with a TECH II you can have them program it out. Apparently you can also plug in some resistors in the correct value to fool the computer into thinking they are still there also. Someone will come along and give the value momentarily.
You may however not be able to program out just the front shocks... The rear shocks will still need to receive a signal from the computer to function at all.
