Ignition Switch Again?
The HOT in RUN/START voltage comes from the ignition switch. If that voltage out of the ignition switch is compromised due to dirty/burnt contacts, you have TWO options. Order a new switch OR attempt to service your switch.
NOTE! Attempting to service your own switch isn't for the everyone. There are several procedures that SHOULD be conducted before you service the switch and after its serviced. Use an OHM METER and read the contact resistance BEFORE you take it apart. Record those resistances.
SERVICING THE SWITCH, Ive detailed that procedure at the beginning of the thread, HOWEVER, some people either don't understand what I wrote, don't have the skills to do it correctly or don't fully test the cleaned switch to verify that it was done correctly.
I mentioned re-bending the contact arms to allow them to close with more contact pressure. When you do that, you MUST insure that the contacts close and they close FLAT with the fixed contact. That involves sanding between the contacts to reform the faces.
Once the contacts are reformed, you must polish them and CLEAN them so that there is ZERO resistance (or as close to zero as you can get).
USE AN OHM METER to insure that the switch has zero resistance in each closed contact position.
Before you reinstall the ignition switch, take a very close look at the harness connectors that connect to the ignition switch! The female pins can and do spread apart. When this happens, you get poor contact and again, compromised voltage into the ignition switch. The correct method of testing those female contacts is to insert a male pin into the female pin to see if there good INSERTION & RETRACTION resistance (force) of the male pin. If its flops in and out, that pin is bad and need to be replaced or re-bent to make proper pin contact with the male pin.
Checking the ignition switch output voltage to a module is easy. The HOT in RUN/START bus goes to a module fuse. On top of each fuse are TWO small test points. Read each of those test points to chassis ground. You should see full battery voltage on BOTh of those contacts. If the voltage is less than battery voltage, the greater the difference the worse the contact or ignition switch voltage path is.
NOTE! The DC VOLT METER on the IPC and the digital voltage reading on the DIC "DOES NOT" indicate true battery voltage!!! It indicates voltage out of the ignition switch! If you have a low voltage on either of those indicators, compare them to the ACTUAL voltage directly on the battery terminals (engine off & engine ON)
Good luck my friends
Bill Curlee
Wire checked everything, chased everything I could think of right up to the BCM. So, I was looking at maybe a BCM replacement until I noticed that the BCM was what looked like a new "REPLACEMENT" box. Somebody else had been chasing this ghost too. So I sit down with the wiring diagrams and checking power. The fuses for the AC, the TCS, backup lights and the O2 sensors didn't have power. Those were all fed from one common terminal in the ignition switch. Hum, so I pulled those 4 fuses, switched the car on and the line side of the fuse slot was hot. Plugged the HVAC fuse in, it started working. Plugged the TCS fuse in, it killed the feed.
That one terminal in the switch would carry some load, but all 4 fuses in on the load and it would loose power. So, I found this thread, read it and I yanked that switch out. Sure enough, had 2 contacts burnt and corroded pretty bad. Cleaned them up and slapped it back together. It's running great now. HVAC runs, lights for the TCS are out and I guess the O2 sensors were nuts due to low or erratic voltage. I'll drive it tomorrow when these storms pass but I think it's good now. AND, again, THANKS Bill
Thanks to all that have posted about the switch.
I am thinking that I should try running relays for the headlights and high beams. And see if that hopefully solves this problem.
I don’t want to run another line from the starter.
I don’t want to run a line from the alternator, since that is controversial… let’s not debate that here.
I also don’t want to run a line through the firewall.
Here is my question:
Could I grab my power by connecting into the horn relay?
So, headlight switch to new relay1, high beam switch to new relay2, and loop the power over to new relay1 and new relay2 from the power terminal on the horn relay.
Now the breaker in the headlight switch is 30-amps I believe.
The fuse for the horn is 20-amps I believe.
I believe with both the high and low beams on, I’m drawing …. What…. Almost 20-amps?? Right? I guess I should look and see what the watts are on the lights, but they are probably 55x2 low and 65x2 high….
And the horn… probably draws 5-10 amps???
So I’m thinking if I have the highs and lows on, then lay on the horn, I’ll blow that fuse…. Right?
So I wonder if I replace the 20-amp fuse with a 30-amp if there would be a problem. None of the 3 individual relays would ever draw that much individually, so I’m not worried about the relays… but the line from the fuse block to the horn relay… does anyone know if that wire is ok for 30-amps?
OK, what are you trying to do here that you need to install new relays for your lighting ??…best to start a NEW thread instead of hi jacking this one since your issue is not related to this post…thanks !!
