Need ABS Help on C5
Old Apr 11, 2017 | 07:41 PM
1Patriot's Avatar
1Patriot
Default Need ABS Help on C5
I have 2004 Corvette coupe. Suddenly I have the ABS and the Anti-skid lights on the dash. The car has not been driven for a while.
The codes for TCS reads NO COMM
The battery is charged and very new.
Help
Where do I start?
Need diagram of ABS circuits and location of the ABS Module. I know where the ground points are on the front frame rails.
Old Apr 12, 2017 | 01:40 PM
oelarse's Avatar
oelarse
First I would check if I have proper voltage from Battery and ignition switch ( Term A and B on the EBCM) . I would also check if the grounds G103 and G108 are good .
Old Apr 12, 2017 | 11:27 PM
Bill Dearborn's Avatar
Bill Dearborn
No comm may mean there is an issue with the EBCM power/ground but could be an internal fault as well. G108 is the main power ground for the EBCM. G103 is the ground path for the BPMV that goes through the EBCM but doesn't affect the EBCM electronics.
First thing to do is to check the ABS fuses and G108 ground. Then check the EBCM power ground connections in the connector that attaches to the EBCM.
Bill
Old Apr 20, 2017 | 07:38 PM
1Patriot's Avatar
1Patriot
All grounds are operating as designed. Cleaned and reset all grounds. Still have the ABS light and the Stabilization lamp on the dash. Message is SERVICE VHICLE SOON.
Any guidance to help is appreciated.
To Need ABS Help on C5
