Doing A balancer job on a 2001
Going to do Melling Hp Oil Pump - its the same as M295 but with
10% more pressure(and parkarkized gears, etc)
I have both chain sets in front of me.. Single & DOuble.
How much of a pain in the *** to use the Double Roller??
IT comes with the 2 spacer pieces, and the Crank Drive piece
is Shorter than the single (compared to each other.)
You'll have to clearence the timing cover and grind down the oil pump mounting bolts, unless new pump came with new ones. Honestly if its just a daily I wouldn't mass with it, just get the ls2 chain.
Just installed a double row chain on my LS1... giant PITA
Grind, check clearance, repeat.
I wouldn't have bothered, but I already had the timing set.
Skip it!
