Too much torque?
Old Sep 26, 2002 | 11:32 PM
scool93535's Avatar
scool93535
Default Too much torque?
I took advantage of a dyno run reciently. The results indicate my numbers for torque are greater the HP, example 322hp & 327lb/ft. .
What gives? Small blocks ususally make bigger numbers for HP then TQ? :crazy:
Today I had the same shop adjust the WOT A/F. They work was done on a different dyno. The numbers are a little different but, the TQ figure is still greater then the HP? :crazy: The work picked up about 15hp and, it looks like a little more TQ, ~20lb/ft. :D It does seem to have improved WOT performance, especially here at my home altitude ~2500ft.
Am I missing something?
Old Sep 26, 2002 | 11:54 PM
Moundir's Avatar
Moundir
Default Re: Too much torque? (scool93535)
TQ is your friend :yesnod: repeat after me TQ is my friend :D
You probably got the extra TQ from the exaust you have. Usually you'll pick up more tq than hp with an exaust system :cheers:
Old Sep 27, 2002 | 11:03 AM
scool93535's Avatar
scool93535
Default Re: Too much torque? (Moundir)
TQ is my friend,
TQ is my friend :jester
I agree, I'm just not use to seeing the TQ figure higher then the HP. :confused:
Oh well, as long as I have a friend named TQ, all's right with the world.. :cheers:
Old Sep 27, 2002 | 12:02 PM
carpe dm's Avatar
carpe dm
Repeat after me..... send all "extra" torque to Greg, send all extra torque to Greg................ :D
Old Sep 27, 2002 | 12:54 PM
MikeV's Avatar
MikeV
You think yours is out of wack... Mine are 304 HP and 329 torque on a A4.
Mike V
Old Sep 27, 2002 | 01:01 PM
YO-EL's Avatar
YO-EL
Default Re: Too much torque? (MikeV)
HP ain't no good, unless you can put it on the ground! :yesnod:
Old Sep 27, 2002 | 02:23 PM
pburant's Avatar
pburant
Default Re: Too much torque? (indypace78)
One of the desirable things about a V-8 motor is that you more often than not have a torque peak that is significantly lower in the rpm band than the peak HP. This is what gives the car drivability - you have copious amounts of torque at cruising rpm, so you can accelerate to a reasonable degree before forcing a downshift. If you want a peak torque figure that is lower than your peak HP figure, go get yourself a VTEC. :jester
Old Sep 27, 2002 | 02:44 PM
scool93535's Avatar
scool93535
Default Re: Too much torque? (carpe dm)
TQ is my friend. :D None to spare for Greg. :cheers:
Old Sep 27, 2002 | 03:17 PM
pasender's Avatar
pasender
Default Re: Too much torque? (pburant)
Well you can also get an M3 or a F360 Modena :D
It's just a different kind of driving !!!
Old Sep 27, 2002 | 04:03 PM
gojo's Avatar
gojo
Horsepower is a mathmatically arrived at number. The formula is: TQ x RPM's divided by 5250. HP and TQ always cross at 5250 RPM's, on a dyno graph. If they don't the graph is wrong. If you want your HP to exceed TQ you can do it with a bigger cam, better breathing and higher RPM's.
[Modified by jfpilla, 3:10 PM 9/27/2002]
Old Sep 27, 2002 | 04:07 PM
LT1pwrd'94's Avatar
LT1pwrd'94
Or your power numbers could look like mine:rolleyes:. Wonderful tq to work with(LT-1), but not much horsepower above 4500:nopity. I think i would take your power curve any day. :D
To Too much torque?
