Bucking in 2nd Gear
Old Apr 25, 2017 | 03:47 PM
harryk387's Avatar
harryk387
Default Bucking and surging after cam install
Car is a 2004 C5 Z06. Major engine mods include:
LG Super Pro 1 3/4" Long tubes with catted x-pipe
LG G5XE Cam/Comp 921 Valvesprings
Ported 243 heads
Vararam Intake
Dyno Tune
Soon as I get below 1000-1100 rpm, the car starts jerking and bucking, the lower in the rpm range I get, the worse the bucking gets. Also, when the engine is hot/outside temps are over 85 degrees, engine doesn't want to turn over. What could be causing these issues? I know it's a tuning issue but it seems the tuner that did the original tune after the cam install is having issues fixing these issues.
Would having the stock fuel injectors be causing these issues? Or maybe the vararam? Anything else that could be causing the hot start issue and low rpm bucking and surging?
Car put down 450rwhp/430rwtq and runs strong but I also feel that it may not be running as strong as it could.
Old Apr 25, 2017 | 03:58 PM
Macleod52's Avatar
Macleod52
I'm interested as well. Occasionally, I'll get bucking when off the throttle, in gear, with low RPMs, while decelerating. Giving a little gas corrects the problem. My car is stock except for a vararaam, x-pipe, and exhaust.
Old Apr 25, 2017 | 04:03 PM
harryk387's Avatar
harryk387
Is it just in 2nd gear?
Old Apr 25, 2017 | 04:13 PM
Macleod52's Avatar
Macleod52
I think it may happen in more than one gear. It's rare that it happens (I imagine based on my driving habits) so I can't say for certain. I want to say I recall in a couple different gears.
Old Apr 25, 2017 | 08:56 PM
AmbulanceDriver's Avatar
AmbulanceDriver
My big single turbo race car did this...couldn't figure it out just chalked it up to being a fuel pump surge or the clutch
Old Apr 26, 2017 | 09:18 AM
DVUSz06's Avatar
DVUSz06
I would expect that at 1000-1100 rpm in second gear slowing to stop, it's speed, rpm, gear ratio and load. I would expect bucking worse in 3rd gear in that situation. Heck all manual trans cars will do that if speed is to slow for gear selected. It's not an auto so won't act like one. Heck it will even do that in first if wheel speed slow enough.
And yes depended on the cam this will be exaggerated, all is normal just drive it like a manual and not an auto.
Old Jun 25, 2017 | 11:25 PM
harryk387's Avatar
harryk387
Bump for more opinions and suggestions. Edited the original post to add better detail.
Old Jun 26, 2017 | 12:07 AM
StingrayRebel's Avatar
StingrayRebel
why are you lugging the engine at such low rpms?... any car will buck if you let the rpms drop low enough and your car has a decent sized cam and making good power so that may be all it is... quit driving it like a baby... if you have stock injectors you should look into replacing those, your tuner should be able to tell you the duty cycle but my stockers were damn near maxed around 420rwhp... as far as the hot start issue maybe have the battery checked, heat will finish them off when they are weak and on their way out
Old Jun 26, 2017 | 12:45 AM
grantv's Avatar
grantv
100%, below 1000-1100 is asking for bucking, particularly with any sort of cam.
Old Jun 26, 2017 | 07:21 AM
ArtClassShank's Avatar
ArtClassShank
Could be the cam. I've looked into this, many say the non-screened MAF on the 02+ Z06's can make it a bit worse. Some suggest the Haltech honeycomb insert to meter the air better.
Old Jun 26, 2017 | 03:24 PM
harryk387's Avatar
harryk387
I don't think having it buck violently around 1000 rpm is normal with this cam considering it's supposed to be a street able daily drivable cam. Also, I don't know about you guys but when I'm driving around a parking lot looking for a spot I'm not flooring the gas pedal, I'm usually in first gear with my foot off the gas coasting at idle. Don't consider that necessarily babying it. Same with bumper to bumper traffic. I've had other manual transmission v8 cars and have never had this issue with those cars.
For the hot start issue, have this issue even after new battery installed.
Old Jun 26, 2017 | 06:29 PM
grantv's Avatar
grantv
Have you had V8 manual transmission cars with a similar cam? I find my stock cam Z is pretty touchy that low, as was my only other V8 manual car (more aggressive cam than the Z).
Old Jun 26, 2017 | 10:15 PM
harryk387's Avatar
harryk387
Here's a link to a video of my hot start issue. Will try to get a video of the bucking as well. It feels more like a tuning issue to be honest.
Old Jun 27, 2017 | 02:23 AM
ajohn20n's Avatar
ajohn20n
https://youtu.be/f9JZoNWhzrs
I've run into a similar issue ever now and then, regarding the start. I never had any problems with it prior to installing my cam (a little smaller than yours, so to speak). If I have my A/C or even just the fan running, my 03Z does the same thing. I just feed it a little more throttle until the idle smooths out. Takes anywhere from about 5-10 sec. Again, that's only when I have extra load such as A/C on and the engine hasn't been running for a bit.
Old Jun 27, 2017 | 07:02 AM
vettenuts's Avatar
vettenuts
It's most likely the overlap in the cam. My cam is slightly smaller and does the same thing. Just one of the things you have to work around with a cam sometimes. I just drop another gear to get the RPM out of the range.
Old Jun 27, 2017 | 06:40 PM
cv67's Avatar
cv67
St. Jude Donor '05
change of driving style needed , just part of having a cam.
Old Jun 27, 2017 | 07:28 PM
StingrayRebel
looking at your video I think the tune needs to be cleaned up, it might have too much fuel or not enough at startup but it definitely shouldn't do that
Old Jun 28, 2017 | 11:49 PM
edram454's Avatar
edram454
start up is your tune. it should not just turn off. I have a cammed z06 lsa112.. 232/234 at 600/600 lift and I cant go around 1000k without some bogging. car runs well except when running around at 1100k.
Old Jun 29, 2017 | 04:47 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Definitely Absolutely tuning issues! That fact that your gut is telling you this should alone be enough. Lets review....
Car put down 450rwhp/430rwtq and runs strong but I also feel that it may not be running as strong as it could. For a Z06 cammed with ported 243 heads car, these numbers are almost dead on when just doing a simple google search to see what others were able to accomplish.
Would having the stock fuel injectors be causing these issues? Or maybe the vararam? Anything else that could be causing the hot start issue and low rpm bucking and surging? Being you are running the stock injectors, this would be a great question for a new tuner to investigate. Just common sense logic would point me to you having a fuel issue or a spark issue upon startup. (there can't really be anything else). Have the tuner look at the car when you are having the hard start issues...my guess it something is going to turn up in the tune.
This leads us to your statement, that to me...sums it all up!
I know it's a tuning issue but it seems the tuner that did the original tune after the cam install is having issues fixing these issues. Its clear you're not happy or confident in your tuner. Nothing can be worst then that. Not trusting someone fooling around with your car just plain sucks! Definitely seek out another tuner. Call around, put up a post asking for recommendations and someone that comes highly qualified in your area. Good Luck! You'll get it sorted out, you just need someone who knows their stuff to take a look at it! I could offer recommendations like anyone on here but quite honestly, you really need a qualified tuner to look at the car. Way too many variables just to just make a general consensus and might end up having you go down the wrong path.
To Bucking in 2nd Gear
