Help with rim problem
Old Apr 26, 2017 | 07:32 AM
Titanlex's Avatar
Titanlex
Default Help with rim problem
Just got C4 zr1s for my o3 z 17x11 put them on and the inner rim rubbing on top of upper ball joint in the rear any help on why this is happening and what the fix is, tires are Mickey Thompson 305/45/17 if that helps. Thank you appreciate all the help
Old Apr 26, 2017 | 08:53 AM
grantv's Avatar
grantv
Because the offset was made to fit a C4? Spacer time... others will chime in with more information.
Old Apr 27, 2017 | 08:52 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Old Apr 29, 2017 | 09:06 AM
UstaB-GS549's Avatar
UstaB-GS549
I'm going to guess that these are are not OEM wheels and you will need a spacer.
My 17x11 black GS wheels don't rub in the rear of my ZO6. They have a 50 mm offset. OEM ZR1 wheels had a 36 mm offset which means they have another 14 mm of clearance on inside and would stick out farther.
Back spacing on my 17x11 GS wheel is 8". (From back of rim to mounting surface) I ran 335 17's on the back without rubbing and had -1 degree camber in the rear.
To Help with rim problem
