Valve spring life?
Old Apr 26, 2017 | 08:47 PM
Ritch_Z06's Avatar
Ritch_Z06
Default Valve spring life?
I got a c5z with a crane cam 216/216 .571 .571 115lsa, dual spring crane springs, with 1.8 ratio rockers as well as twin turbo tuned conservatively on 7lbs. Car is a daily driver. How long would these springs last. I drive 70miles one way all interstate, not too rough on the car only when someone wants to "run." any answers or insights to these springs or spring life will be appreciated!
Old Apr 27, 2017 | 12:49 AM
CactusCat's Avatar
CactusCat
That's a pretty mild cam. Prob a good choice for a turbo car. Those dual springs should last for a long time, but if you're worried, just change them every 20,000-30,000 miles. Unless you really beat on the motor, I'd think they'd last as long as stock springs would last on a stock motor.
Old Apr 27, 2017 | 06:51 AM
vettenuts's Avatar
vettenuts
Do you know which springs you have, the 832's or the 833's? The 832's actually have a harmonic right near 6K RPM so I would swap them out if that were the case and use the 833's instead.
Old Apr 27, 2017 | 12:20 PM
Ritch_Z06's Avatar
Ritch_Z06
I'd have to check which ones they are. Thanks for answers I appreciate it!
To Valve spring life?
