TPMS Sensor day
Old Apr 27, 2017 | 10:28 PM
pjdbm's Avatar
pjdbm
Default TPMS Sensor day
I purchased a Harbor Freight bead breaker for $40.00 and decided to try and change my TPM sensors today.
Wasn't sure these large rims would work with this tool and was set to return it if it didn't.
I got the front two done within and hour and a half, that included jacking up the vette and removing tires.
I used painters tape in the area of contact and also laid a piece of plywood over the rim so it didn't get damaged. It was not simple but very doable with patience and soapy water. After the fronts were done, I did test them and they work, a pleasure to hear that horn go off
Tomorrow will be the rears
Old Apr 27, 2017 | 11:05 PM
FX VETTE's Avatar
FX VETTE
Nice alternative to a tire shop, thanks for sharing!
Old Apr 27, 2017 | 11:24 PM
pjdbm's Avatar
pjdbm
thanks, and by the way, I had absolutely no problem filling the tire back up after sensor was installed.
The aluminum nut should be torqued to about 60 inch lbs
Old Apr 27, 2017 | 11:31 PM
FX VETTE's Avatar
FX VETTE
Since you aren't moving the tire too much during this process, do the tires need to be balanced afterward or should they be good?
Old Apr 27, 2017 | 11:45 PM
pjdbm's Avatar
pjdbm
From all the reading I did on this, this should be no problem, all I opened up was the area of the valve, I didn't even break the back bead.
I just broke the bead enough to access the sensor, I had to search deep for the proper torque, the company I bought these from told me around 24 inch lbs, they were a tad off lol
Old Apr 27, 2017 | 11:58 PM
jcgunn's Avatar
jcgunn
Great job! I find myself leaving tire changes, drywall, and high voltage electricity to the pros!
Old Apr 28, 2017 | 09:51 AM
DetroitPlac's Avatar
DetroitPlac
How do you get the bead to seat again? I've been cruising with dead sensors since I bought the car 2 years ago, figuring I'd wait until I needed replacement tires to replace them. Maybe not...
Old Apr 28, 2017 | 10:07 AM
pjdbm's Avatar
pjdbm
I have a regular 20 gallon compressor and just filled them normally without doing anything extra. I guess the low profile tire keeps it tight enough.
i have read stories where people take the cars to professional?? Shops and they confuse inch lbs with foot lbs and destroy the sensors. I have very little confidence with the mechanics and especially the tire shops around me here on Long Island.
I doubt very much that they use a torque wrench on the either.
Old Apr 28, 2017 | 03:53 PM
Nicely done - thanks for the tip on what to use if you want to make it a DIY project.
Old Apr 28, 2017 | 04:42 PM
FX VETTE's Avatar
FX VETTE
100%
When I had my new tires installed & all wheel alignment done at a major tire chain store - they put 46 psi in all 4 tires and my steering wheel was crooked.
I believe I may try your method when my sensors start giving out, which should be soon as they are 14 years old.
Old Apr 28, 2017 | 11:40 PM
pjdbm's Avatar
pjdbm
Thanks for the kind words, I finished the rears today, the rears were harder than the fronts.
In the future, I will do maybe one or two but not all four, I am 52 and the risk of injury with the force/pressure that needs to be applied getting access with a low profile tire may not be worth it, when I get older will probably take the wheels to a shop and then recheck their work.
It was interesting and a hell of a experience. Oh, I got them all programed and what a joy it is to have the tire monitoring system working. I took her out for a cruise and all tires are good.
Old Apr 28, 2017 | 11:44 PM
FX VETTE's Avatar
FX VETTE
So, end result advice = have a tire shop do it and try to supervise?
Old Apr 29, 2017 | 12:01 AM
pjdbm's Avatar
pjdbm
To be honest, yes
Took about 3 hrs, I did it in two days, having to jack up the car and running airlines and setting up each day.
Old Apr 29, 2017 | 11:14 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
....the risk of injury with the force/pressure that needs to be applied getting access with a low profile tire may not be worth it....
Compressing the sidewall takes a lot of force. I don't want my hand in there if it suddenly slips back to uncompressed position.
I have a tire machine with a side mount bead breaker, and I still won't reach in while the tire is compressed. And once the bead is broken the tires still take a lot of force to move it to where the TPMS can come out. Actually enough that I can't do it by hand. Since I have a tire machine, I have to go a step further and dismount at least one edge of the tire.
Good job, and be safe.
To TPMS Sensor day
