C5 Headlight Issue
Old May 2, 2017 | 01:21 PM
Rob0702's Avatar
Rob0702
Default C5 Headlight Issue
I rebuilt both headlight motors on my 2003 C5 after encountering a noisy chattering sound when the headlights closed. All was good for a few months. Headlights open and close quietly, but yesterday when I turned them off when they closed, then the drivers side headlight opened up. I closed it manually, turned headlights on and off and same thing happened. Has anyone had this issue and know what the problem is and how to fix?
Old May 2, 2017 | 07:53 PM
Rob0702's Avatar
Rob0702
So you don't think it's a bad headlight relay or something related to the 2 headlight motor rebuilds I did?
Old May 2, 2017 | 08:18 PM
Rob0702's Avatar
Rob0702
Thanks for the info. I will check it out and see if any of my stops are damaged or fell off. If they are still intact, it's on to the shims!
Old May 2, 2017 | 08:52 PM
Rob0702's Avatar
Rob0702
Okay. Thanks for the great info. I will certainly seek him out if need be.
Old May 2, 2017 | 09:38 PM
GCG's Avatar
GCG
And here are the rubber bump stops.
Old May 17, 2017 | 08:12 PM
Rob0702's Avatar
Rob0702
Default Bump Stops
Originally Posted by 8VETTE7
If you are missing the Bump Stops show in the pics above, the only place you can currently get replacements is from Rodney Dickman. Look for them on his sight if you need them. GM has not made them in many years..........
The bump stops were the problem. The D/S headlight had one bump stop that looked like it had a cut in it where it makes contact with the stop. I flipped it over and headlights closed now. However, it's showing signs already of it being damaged already. What could be causing this? I'd hate to buy and keep replacing new stops if they're going to continually get damaged.
Old May 18, 2017 | 07:13 AM
lionelhutz's Avatar
lionelhutz
Shim it. Make sure the arm will hit the metal stop without the stop on it first and then install the stop again. Otherwise, the arm will just damage the end of the stop again until it goes past it.
Old May 18, 2017 | 08:59 AM
Rob0702's Avatar
Rob0702
Well known drivers side headlight issue. There is a shim kit available to correct the issue. I suggest the kit from Rodney Dickman. Here:
http://rodneydickman.com/catalog/pro...roducts_id=333
Kit from GM, if you can still get it, is much more than Rodney charges...
Thank you. You have been a great help. Ordered the stops, now ordring shims. From what I can see, I remove headlight motor and put the shims between motor and bracket and it should align it all better than original.
Old May 18, 2017 | 09:57 AM
lionelhutz's Avatar
lionelhutz
Wow, $1.60 a washer to get them in black? They'd cost pennies from a hardware store that sells in bulk.
To C5 Headlight Issue
