Urban Legend? LS1 Programming...
Old Sep 28, 2002 | 12:09 AM
Katz's Avatar
Katz
Cruise-In III Veteran
Default Urban Legend? LS1 Programming...
I heard a rumour that solely through programming one can make a 200mph C5 with a stock LS1. I doubt this is true, but I honestly don't know if this is possible. Is it possible? Can anyone shed any light on this?
Thanks!
Old Sep 28, 2002 | 12:51 AM
DsC5's Avatar
DsC5
Default Re: Urban Legend? LS1 Programming... (Katz)
I don't have enough specific knowledge to give you a complete answer, but I'd say that the most important factors determining top speed and therefore whether a stock LS1 C5 could hit 200 mph are: 1)engine power output; 2)gearing; 3)aerodynamics.
The way I see it, programming affects none of these, with the exception of you may be able to squeeze a bit more power out of the engine, but certainly not enough to add 25+mph to top speed.
Bottom line, :bs :seeya
Old Sep 28, 2002 | 12:55 AM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
no way with a stock LS1.
Old Sep 28, 2002 | 01:06 AM
Katz's Avatar
Katz
Default Re: Urban Legend? LS1 Programming... (kewlbrz)
That makes sense.
I was told by a friend that a "friend of a friend" of his worked in GM engineering and claimed they could make a 200mph C5 by very finely tuning the fuel air mixture. It was almost believable but not quite.
[Modified by Katz, 11:12 PM 9/27/2002]
Old Sep 28, 2002 | 01:57 AM
Flintstone's Avatar
Flintstone
Horsepower to reach 200 mph is just north of 500 hp.
F
Old Sep 28, 2002 | 03:48 PM
Hib Halverson's Avatar
Hib Halverson
Pro Mechanic
Pro Mechanic
Default Re: Urban Legend? LS1 Programming... (DsC5)
Stock LS1?
Simple reprogramming and you'll go 200
The subject line of this thread says it all.
Ok....well, maybe God can go 200 in a stock LS1 with simple reprogramming.
Old Sep 28, 2002 | 04:06 PM
Shag Finger's Avatar
Shag Finger
Well technically you can make a 200 MPH LS1 by removing the speed limiter, that would LET it go to 200.....now getting it there is another story :lol: :smash: :cheers: :D :jester
[Modified by **** Finger, 8:06 PM 9/28/2002]
Old Sep 28, 2002 | 08:29 PM
Tom Steele's Avatar
Tom Steele
Default Re: Urban Legend? LS1 Programming... (Flintstone)
I don't know about that. I think you could re-gear a Z06 and get very very close to 200 without any extra hp.
How are you getting that number?
Tom Steele's Avatar
Tom Steele
Default Re: Urban Legend? LS1 Programming... (**** Finger)
Does the LS-1 have a speed limiter in it?
Old Sep 28, 2002 | 08:40 PM
Blocktrdr's Avatar
Blocktrdr
With a 50 MPH tailwind you could probably hit 200 with no programming.
Old Sep 28, 2002 | 09:21 PM
Shag Finger
Default Re: Urban Legend? LS1 Programming... (Tom Steele)
I thought that I remembered hearing that it was speed limited to like 175 or something. But then again I could be wrong....wouldnt be the first time :hat
Old Sep 28, 2002 | 09:26 PM
Big Carrot's Avatar
Big Carrot
Not gonna do it.....wouldn't be prudent :lol: :lol: :lol: :lol:
Old Sep 28, 2002 | 10:27 PM
tscales's Avatar
tscales
St. Jude Donor '07
Nope, no speed limiter.
There is a rev limiter.
Maybe you could raise the rev limit to 10,000 and get to 200mph.
Once.
Tom
Old Sep 28, 2002 | 10:47 PM
corvette_karl's Avatar
corvette_karl
Default Re: Urban Legend? LS1 Programming... (tscales)
Maybe it was getting pushed by a McClaren F1 or something :smash:
or maybe they were running 42" wheels and tires or something (effectively gearing it). :lol: Imagine what that would look like! :troll
Seriously, you'd have to gear it, among probably quite a few other things.
Karl
Old Sep 28, 2002 | 11:10 PM
lost's Avatar
lost
Easy, 2.73 gears and tune it to run on nitromethane...
Old Sep 29, 2002 | 12:32 AM
Flintstone's Avatar
Flintstone
Got that # from the Lingenfelter site, with a little interpolation:
http://www.lingenfelter.com/nov98.asp
"We also knew from previous top speed testing roughly how much horsepower it took to achieve 200 mph in a C5 Corvette. 214 mph would have required almost 500 HP at the rear wheels and we knew we were not at that level of power."
Interpolating for the 14 mph difference, I think I was being conservative.
F
Old Sep 29, 2002 | 01:01 AM
HIGHRPM's Avatar
HIGHRPM
200 mph is not possible with a stock LS1....the top speed isn't a function of the rev limiter or tire size....it just runs out of HP at 175 mph....top speed in any car is reached with the proper tire size, differential gears and a transmission gear that allows peak HP level revs. :cheers:
Old Sep 30, 2002 | 09:12 PM
Tom Steele's Avatar
Tom Steele
Yep, if their data is right, your numbers look reasonable to me. (Although we are getting into some seriously exponential functions and they are starting to get into some steep curves here, so I'd allow a bit more leeway in the guesstimate.) I would have guessed much lower. We are into 170 mphs now, and the c/d is low on these cars. I would have though that with the right gearing, you could get a Z06 to at least 190...
[Modified by Tom Steele, 7:13 PM 9/30/2002]
Old Oct 1, 2002 | 01:27 PM
QwikSilvr's Avatar
QwikSilvr
Default Re: It's possible....
All you have to do is get a cargo plane, go to a high altitude and roller her out the cargo bay. She'll definitely hit 200 MPH before hitting the ground :lol: :crazy:
To Urban Legend? LS1 Programming...
