front wheels rub when turning after an alignment
Old May 10, 2017 | 02:55 AM
vectorz's Avatar
vectorz
Default front wheels rub when turning after an alignment
I had recently removed my leaf springs and switched shocks to coilovers (pfadt 1st gen). Immediately after installing the coilovers took it to my local Firestone to get alignment, since they've been doing my alignments on this car for the past 13 years and I have lifetime alignments with them. Anyhow after the alignment they said everything is now in spec but when I drive it if I turn even the slightest I get tire rub against the arch of the inner fender as well as the air duct inside the fender , either direction I turn. I saw in a thread that during an alignment it's possible they may have adjusted the wheel position too far forward https://www.corvetteforum.com/forums...post1556451332 . If that's true, does anyone know what bolt needs to be turned or what mechanically needs to be adjusted to get that wheel moved back?
One of the things that might give a clue is when I dropped the leaf spring I removed the lower control arm on the driver's side. When doing that, there was an alignment related washer on the large bolt. Does this have anything to do with it?
Old May 10, 2017 | 06:13 AM
Mickeyrx70's Avatar
Mickeyrx70
Old May 10, 2017 | 09:17 AM
v8srfun's Avatar
v8srfun
Post pics of the car. There are many factors like how low are you and what tire size are you running
Old May 10, 2017 | 01:29 PM
vectorz's Avatar
vectorz
Will do but note that the front now with the coilovers sit much higher than it did when I lowered it on leaf springs
Old May 11, 2017 | 02:56 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by vectorz
.....If that's true, does anyone know what bolt needs to be turned or what mechanically needs to be adjusted to get that wheel moved back?
The only thing that realistically will "move" the position of the front wheel, is the caster adjustment. You set the camber of the front wheels, primarily, by moving the front bolt of the lower a-arm, then you adjust the caster with the rear bolt.
Picture the front wheel of a bicycle, where the fork curves forward, as it drops to capture the axle. This forward angle is "caster". It gives you stability in a straight line.
When you set caster on a car, you're adjusting the angle of the car's spindle, with respect to the centerline of the lower ball joint compared to the centerline of the upper ball joint. You want the lower ball joint to "lead" the upper, by a little bit. On a C-5 Corvette, you do this by turning the "eccentric" pivot bolt on the rear of the lower a-arm. It does, however "move" the wheel forward, a tad.
Based on the modifications you made, especially if the car is now higher, you've moved the position of your wheels, within the wheel wells.
Old May 11, 2017 | 04:52 PM
StingrayRebel's Avatar
StingrayRebel
post a pic of your alignment printout
Old May 11, 2017 | 05:19 PM
leadfoot4's Avatar
leadfoot4
That would be helpful.
Old May 12, 2017 | 01:18 PM
lionelhutz's Avatar
lionelhutz
Also check if they used shims on the upper arms instead of adjusting the lower arms. They could have added shims on the upper arm because the lower a-arms were adjusted oddly.
I had a shop tell me a different car I have couldn't be aligned correctly because they were only trying to adjust the upper a-arms with shims. But, it had lower a-arm adjustments they weren't using.
The lower a-arm has 2 bolts with 4 x eccentric washers (one on each side of each bolt). You should mark the washer to frame alignment if you remove them and keep them in the same positions so they go back together were they came from. This at least gets the alignment reasonable until you get it to a shop. These bolts should get adjusted when the shop did the alignment.
There isn't an adjustment that simply lets you move the wheel position. You can adjust the lower a-arm to move the lower ball-joint backwards, but that will also lower the caster. It's then possible to use shims on the front bolts of the upper arm to compensate and put caster back into the car.
Old Oct 8, 2017 | 09:35 AM
Gary barnes 1098's Avatar
Gary barnes 1098
Default Height
my 14' z51 has the lowering bolts all the way down. I noticed my front right sat about 1/4 lower,so I just raised that bolt so both the same. I hope I'm ok???
To front wheels rub when turning after an alignment
