Odd technical question
Old Sep 28, 2002 | 01:06 PM
DsC5's Avatar
DsC5
Default Odd technical question
So I'm looking out my window at the car, and the wheel spokes are almost lined up perfectly, i.e. front a rear wheels are in the same position.
Now, I know they are always in different spots and I was trying to think why. First I thought - if the rear wheels break loose - then it would alter their position. But - I drive slow - so they never break loose.
So then I thought - the wheels are different diameters - 17in. v. 18in. Therefore the mathematician in me starts thinking - for every X distance my car travels, the front wheels total more rotations than the rears - because the circumference of the wheels varies.
Does this make sense to anyone? Or am I just :crazy:
:seeya
Old Sep 28, 2002 | 01:14 PM
Roofless's Avatar
Roofless
St. Jude Donor '11,'13
Default Re: Odd technical question (DsC5)
Bored today are we?
Old Sep 28, 2002 | 01:20 PM
CJS's Avatar
CJS
Keep in mind also, that if you go around a corner, then the outside wheels travel farther than the inside wheels, sorry to complicate your computations.....
Old Sep 28, 2002 | 02:31 PM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
Default Re: Odd technical question (CJS)
Also keep in mind that the GY Runflats have such hard sidewalls that when you hit a small bump the tires bounce up and down off the pavement, so the backs turn more than the fronts when that happens. I would say that this happens around 1.3762 times per 3.224 miles, depending on whether it is in a construction zone, which in CA is about every 14.63 miles. Now if you figure in potholes, which cause more bouncing, then you have to go to San Francisco to measure those, but they are probably around around 3 per block and about 14 inches in diameter...enough to eat a tire...soooo Let us know when you get the answer and we can line up our tires. :D
Old Sep 28, 2002 | 02:46 PM
tscales's Avatar
tscales
St. Jude Donor '07
The diameters are different. The fronts turn more rotations then the back for the same distance.
Nothing magical.
Tom
Old Sep 28, 2002 | 03:07 PM
Crushinator's Avatar
Crushinator
Default Re: Odd technical question (tscales)
What you're saying makes sense but in all honesty, go outside and find something to do! :lol: :seeya
Old Sep 28, 2002 | 08:54 PM
Old Rotor Head's Avatar
Old Rotor Head
Man, I wish I had that much time on my hands :confused:
Old Sep 28, 2002 | 09:04 PM
nevadacoin's Avatar
nevadacoin
Default Re: Odd technical question (Old Rotor Head)
ahhhhhhhhh..Lets clean those wheels again if we have that much time on our hands... :lol: :lol: :lol:
Old Sep 28, 2002 | 09:22 PM
Corvette Poor's Avatar
Corvette Poor
Nothing magical.
Tom
Hummmmmm.. :confused: Then WHY do the rears always wear out first ?
Old Sep 28, 2002 | 11:08 PM
corvette_karl's Avatar
corvette_karl
Default Re: Odd technical question (Corvette Poor)
I've noticed this too, and have also noted that they will stay aligned that way as long as you don't lift or move the car :lol:
Old Sep 29, 2002 | 12:09 AM
rrobert22's Avatar
rrobert22
Nothing magical.
Tom
Hmmmmmmmmm......Gas pedal :yesnod:
Old Sep 29, 2002 | 01:16 PM
DAWS C5's Avatar
DAWS C5
You might try switching the left rear and the right front. This way they will average out all the effects others mentioned. Unless of course you also make left turns. Then you periodically need to switch them back and then switch the left front with the right rear. This should do it for you. Unless you don't keep exactly the same tire pressures in all wheels. :rolleyes:
:seeya
Old Sep 29, 2002 | 02:56 PM
Closer_2001's Avatar
Closer_2001
Turning the car changes the rotational speed. Outside rotates faster, inner rotates slower.
To Odd technical question
