Squeaky Glass Top
Old Sep 28, 2002 | 03:50 PM
tds69tx's Avatar
tds69tx
Default Squeaky Glass Top
My glass top has started creaking and squeaking :confused: . Is there any adjustments for this??
Thanks--
:cheers:
Old Sep 28, 2002 | 05:06 PM
Ranger's Avatar
Ranger
Default Re: Squeaky Glass Top (tds69tx)
Here is the fix that worked for me on my 98 coupe.
Remove the glass top. Carefully clean all the weather striping on the top and the mating surfaces on the windshield and targa.
Then apply a thin coat of silicone grease (the type made for weather striping; some folks swear by Krytox brand) to all the mating surfaces. Allow it to soak in and then lightly wipe off the excess.
Also lube the clamps and their bed-down points with a very thin coat of say WD40 or a teflon lubricant spray. Wipe off the excess.
Replace the top.
The whole process will take under an hour and the top will again be seen and not heard.
Ranger
Old Sep 28, 2002 | 10:51 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Default Re: Squeaky Glass Top (Ranger)
yes, lube the weatherstrips. I used ArmorAll and it did the trick.
Old Sep 29, 2002 | 11:10 AM
1999 White C5 Coupe's Avatar
1999 White C5 Coupe
Ranger posted excellent advice. I do the same to my 1999 C5 coupe (both tops) and it prevents the noise.
Old Sep 29, 2002 | 04:30 PM
tds69tx's Avatar
tds69tx
Default Re: Squeaky Glass Top (1999 White C5 Coupe)
Thanks for the advice guys. I was wondering if there is any "mechanical" adjustments?
:cheers:
Old Sep 29, 2002 | 08:38 PM
MelloYellow's Avatar
MelloYellow
Window Lithium Grease spray on the handle contact points.
The metal contact at the handles is what squeaks the most.
Old Sep 30, 2002 | 05:32 PM
jawski's Avatar
jawski
:cheers:
Yes, there are....remove the top....look down into the cam lock at the windshield....you should see two bolts....loosen them to reposition....be careful...you won't need much...a fraction goes a long way.
To Squeaky Glass Top
