Best N/A powered spark plugs
Best advise?
I really appreciate the help. Thank you.
Any thoughts to quality? I figure they are going back for the TR5's, but thought I'd see if this is even a decent plug.
New PLUGS. "Already in progress".
New Plug Wires
CLEAN THE MAF
Clean the throttle body/throttle blade.
Check ALL your vacuum lines and the air ducting between the MAF and throttle body and make sure that they are properly sealed/air tight!
If you'er O2 sensors are old, I STRONGLY recommend replacing them with new ones.
Once you have that base line and the car starts to run poorly in the future, you should only have to FIX something stated above to get back to a good running engine.
Bill
New Plug Wires
CLEAN THE MAF
Bill
I went ahead and picked up AC Delco coils from the Chevy house.
After returning the wrong plugs, I've got the correct plugs you suggested.
I bought Bosch O2's: up stream & down stream. I'm curious if you think those are ok?
I also just replaced the cats and I went with a high performance cat. While I was there, I went ahead and removed my Borla stingers and went with straight pipes over the axles. I like it better. I get a little weight savings and it seems to actually run smoother.
Also, I want to see what your thoughts on GM Hot Wires might be. I have JBA's on the car currently- I didn't install them- they were on the car when I bought it but I'd like for the new to be a good, solid plug wire.
I run a high grade silicone coupler from the intake to the tb; the accordion style couplers create too much air turbulence and tend to rip.
I am wondering if you have or know of a URL link for a good map/layout of a 99 c5 vacuum & pressure line system?
I can spray the vacuum lines with carb spray and listen for idle changes, and I can hit the pressures lines with soapy water to look for bubbles, but a preimptive which-is-which is more helpful.
By the way, you've been graciously helpful & and I just want to say thanks. People like yourself and all the others so willing to generously offer up so much help, well, flat out make this forum and being a Corvette owner so great. I also own a 03 Cobra and the "ford" (Cobra, mustang, set) forums/websites & members are not nearly as knowledgeable, helpful, and most of the time, Without rude attitudes.
