f45 shocks
Old May 18, 2017 | 03:19 PM
slicer127's Avatar
slicer127
1st Gear
Default f45 shocks
how to disable f45 shocks
Old May 18, 2017 | 03:46 PM
SoAlVette's Avatar
SoAlVette
I removed mine, replaced with C6 Z06 shocks and has someone with a Tech II scanner delete them from my computer. There are plug in
simulators you can buy if you do not have access to a Tech II.
Old May 18, 2017 | 03:54 PM
Smoken1's Avatar
Smoken1
However forget buying the simulators, they are only 10ohm 10watt resistors you can get from Radio Shack. You will need 4 of them if you go that route
Old May 20, 2017 | 10:08 AM
kalayaan12's Avatar
kalayaan12
I did the same thing - initially went the "Radio Shack" resistor route for a summer or two until I got the option deleted by someone who had a Tech II scanner.
The simulators are fairly expensive from what I've seen - fortunately the Radio Shack resistors ran about $4.00 for two packs if I recall correctly...
Good Luck!
Jeff
Old May 20, 2017 | 08:19 PM
Greg_E's Avatar
Greg_E
If you have access to a Tech 2 the procedure is in this thread.
https://www.corvetteforum.com/forums...mass-o-ri.html
To f45 shocks
