AC not working
Old May 22, 2017 | 10:02 PM
SaltonSea's Avatar
SaltonSea
4th Gear
Default AC not working
Hi, I have worked as an automotive tech for about 20 years. I only dabbled in AC at that time, but it was working 6 months ago, and now it's not working at all. I would assume that the R134 has just leaked out. I would like to know from the experts if there is anything at all that could cause this, other than a simple leak. I rarely drive the car, so the battery has drained at least once, since the last time the AC worked. Thanks in advance.
Old May 22, 2017 | 11:29 PM
ZZ06's Avatar
ZZ06
Ok first off, post codes(if any). Gonna need some more info in order to help. Is it blowing hot? starting out cold, then hot? Compressor not coming on? Clutch kicking on and off? AC light flashing? Help us help you.
Old May 23, 2017 | 10:28 AM
Corvette#2's Avatar
Corvette#2
Once mine quit blowing cold air. It turned out the compressor failed. Fairly common issue. It spent almost $800 to fix. Lots of labor involved. You have to move the steering rack to get at it .
Old May 23, 2017 | 11:36 AM
chris308's Avatar
chris308
The rack does not need to be removed.
It's common that the compressor case seal is the leak location.
Old May 23, 2017 | 11:54 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
It could be one or more of a DOZEN reasons why it wont blow cold air.
First things first,, You HAVE to read and post your DTCs using the internal code reader. Post up what you have.
When you turn the AC On at the front panel, WHAT does the little orange light do? Blink, Come on and stay on or Not light??
When you turn on the system, does the compressor clutch engage and rotate the center hub? Is the belt driving the outer hub??
Until you actually measure the HIGH SIDE & LOW SIDE pressures, you can NOT accurately diagnose the charge. Beg. borrow or purchase a set of gages and the required hose fittings to attach to the quick disconnect fittings and log the high and low side pressures.
NOTE! If you find that the system is LOW on R-134, purchase an OIL CHARGE and add that with the necessary Freon. Unless you have a gross leak, I would just charge it and make sure that it works properly
IF,,,,,,,,,, the system is EMPTY, you should replace the receiver/dryer, change the orifice tube, pull a vacuum on the system and properly charge it (along with adding all the required oil for the new receiver dryer).
Old May 23, 2017 | 03:47 PM
ianmcgee67179's Avatar
ianmcgee67179
I'm having issues as well, I had the normal actuator issues, and replaced the passengers side actuator, and it's changing temps now which is good, but now when I press the AC button, it blinks then turns off...and but it still says set on the screen...any ideas what that is?!... I still have two HVAC codes (B0361H, and B0363H)....which would make me think I'm still having a drivers side actuator issue? But I still don't know what the blinking light means? Any help?
And my freon is good old as well as my compressor!
Old May 23, 2017 | 07:22 PM
Corvette#2's Avatar
Corvette#2
Oops I must have been thinking about the harmonic balancer. The water pump has to be removed for the compressor.
Old May 26, 2017 | 05:36 PM
ianmcgee67179
so does anyone have any idea why my ac light is just blinking? and my air doesn't start blowing until I play with the range and go full air most of the times?...any thoughts?
Old May 28, 2017 | 03:24 AM
flyingjoey's Avatar
flyingjoey
Make sure u not leaking from low side valve easy to replace valve . Make sure u add oil charge and freon not low..I had leak compressor didn't turn so bypassed it bridge relay under hood for ac.. once forced it took my oil can and freon.. was cold again .. no valve leaks for now.
Old May 30, 2017 | 12:43 AM
ianmcgee67179
why and how did you exactly bypass the relay?.. and are you saying you just had a bad relay and you replaced the relay and it was fine?
Old Jun 5, 2017 | 09:26 PM
My Vette Life's Avatar
My Vette Life
feel free to come over and take the entire ac system out of my car. runs good just have no need in my 2 door
Old Jun 6, 2017 | 02:46 PM
flyingjoey's Avatar
flyingjoey
Hey some high end italian cars don't have access either less weight .
To AC not working
