Harmonic balancer, water pump, alternator???
On the way home after about 20 minutes of driving I noticed a chirping sound. Pretty constant but very noticeable when giving it gas. I got it home and left it running a few minutes. I noticed the temp gauge was nearing 260 and the electric fan was kicking on alot. I popped the hood and noticed the serpentine belt was kinda slow and doing a start-almost stop kinda motion.
That evening I got home and started the car. No chirping, no belt problems, however I just let it run a minute or so.
I was thinking I could have a water pump or alternator dragging on the belt then discovered the harmonic balancer issue on the C5.
Could that be the likely problem here? And if it is, I don't want to go back to the OEM. I see alot of recommendations for the Powerbond with a new ARP bolt. I'm not mechanically inclined so if you have part numbers for those that would be great.
Is there anything else that should be done while things are apart if that is my issue.
Thanks,
Mike
I did this job last year and this is a method I used to hold the crankshaft from turning. This worked great for me and saved dropping the exhaust to remove the starter to place a tool there to hold the crank while removing and re-tightening the ARP bolt.
https://www.corvetteforum.com/forums...ving-bolt.html
