shocks
Old May 24, 2017 | 11:32 PM
IndianaSaltRacer's Avatar
IndianaSaltRacer
6th Gear
Default shocks
After having my C5 as long as I had my C4, and the only thing i cant stand is the ride. Indiana has some crappy roads and i enjoyed the C4 ride much more than this one with the 03Mag ride control.
Any suggestions on shocks or do I need more tire sidewall?
Thanks Dan
Old May 25, 2017 | 12:20 AM
grantv's Avatar
grantv
Get some standard 04 shocks, or aftermarket, and have the mag shock system tuned out?
Old May 25, 2017 | 01:43 AM
IndianaSaltRacer
6th Gear
Thanks Dan
Car has 65k on it, shocks dont appear to be leaking, some dust on them but thats about it.
Old May 25, 2017 | 01:46 AM
IndianaSaltRacer
6th Gear
it's just either too hard or I'm hitting my head on the top over the smallest pavement problems. Northern Indiana gets alot of cold freeze thaw cycling so the roads pretty much suck after one winter. Love it otherwise. No lights, fixed all codes and changed steering degree unit so that TC and all other systems working correctly.
Old May 25, 2017 | 01:47 AM
IndianaSaltRacer
6th Gear
Sorry its a 03 base coupe w/auto and stock LS1.
Old May 25, 2017 | 11:35 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by 8VETTE7
If the shocks don't appear to be leaking then I would start by checking to see if the shock stuffers that the factory adds for shipping and the delivering dealer is supposed to remove before delivery, are still in place.
Easy to do and doesn't cost anything. Here are a couple links about the stuffers:
http://forums.corvetteforum.com/c5-g...uspension.html Post 2
http://forums.corvetteforum.com/c5-g...ck-blocks.html Post #5
A couple more questions about the car.
Does it have run flat tires and if so how old are they? In general run flat tires do not provide a foregiving ride and much less so if they are say 7 or more years old...
What profile tire are you running? 30 series?? 40 series???? or ????
Has the car been lowered??? Is so how much???
100% I lowered my car and it significantly changed the range of suspension travel and I experienced what you are dealing with. I had to raise the car up some to keep the suspension from bottoming out. Check out that SHOCK STUFFER and make sure that they are properly removed, You would be AMAZED at the number of corvettes that are still driving around with them installed.
Bill
Old May 25, 2017 | 11:56 AM
IndianaSaltRacer
6th Gear
Raised to normal heaight , sumitomo's f+r, regular stock sizes, not runflats. 35 series in back 40 in front. Have to look at the shocks, I do remember seeing something yellow sticking out from them. Cant believe they would not have taken them out, but I'll check.
Old May 26, 2017 | 09:10 PM
FX VETTE's Avatar
FX VETTE
The yellow strip you saw hanging out of your shock boot is attached to a shock stuffer. Once you remove them you can truly enjoy the ride.
Old May 31, 2017 | 01:57 AM
IndianaSaltRacer
6th Gear
YUP 4 shock Stuffers!
And they are not in place anymore! Thanks too all, I would never have thunk it possible.
Cant wait to see how it rides tomorrow morning on the way to work.
Yes it is my go to work car.
Old May 31, 2017 | 08:34 AM
FX VETTE's Avatar
FX VETTE
You'll notice a huge difference in the Tour mode.
Old May 31, 2017 | 12:50 PM
jrprich's Avatar
jrprich
Wow !!!!!!!!!!!
65k and still had the SS in..........I thought mine was bad at just under 30k.
How many owners did this 03 have?
Jim
To shocks
