Slave cyl sucking air?
Old Jun 1, 2017 | 02:43 PM
StatmanRN's Avatar
StatmanRN
Default Slave cyl sucking air?
Issues with the clutch not disingaging and making it hard to put into gear while running as well as shifting, and creeping in first.
On most cars I would have said it was an adjustment needed. But there doesnt seem to be any provision for it.
RPS twin carbon and a new delco slave were installed about 4 yrs ago, less than 10 K miles since but the car sat for a year while I had 2 hip surgeries.Not leaking fluid
Replaced master with new delco- remote bled, no improvement. keeps getting fine air bubbles.
At this point, thinking it has to be the slave and sucking air. I find it odd it doesnt seem to be losing any fluid.
Old Jun 1, 2017 | 02:51 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Two common areas where it can get air.
The shaft for the master cylinder
The round cylinder that the slave piston rides on. If it can ingest clutch dust into the slave without leaking, it can also ingest air.
Least expensive part is to swap in a new master cyl and go from there.
BC
Old Jun 1, 2017 | 05:33 PM
StatmanRN's Avatar
StatmanRN
Already did. No improvement.
Old Jun 2, 2017 | 08:29 AM
huesmann's Avatar
huesmann
Is the problem OK after bleeding and deteriorate gradually, or is it not helped by bleeding?
Old Jun 2, 2017 | 04:41 PM
StatmanRN's Avatar
StatmanRN
Not helped by bleeding. In use, its better after pumped a bit The clutch creap is worse when hot, but doesnt seem to get worse while the dlutch is depressed
Old Jun 5, 2017 | 09:18 AM
huesmann's Avatar
huesmann
If you have an OEM-style clutch, maybe you need to reset the "self adjusting" feature of the clutch? See this: http://paceperformance.com/files/pdf/zo6clutchadj.pdf
It's for a Z06, but my base C5 manual has basically the same procedure.
Also:
https://www.corvetteforum.com/forums...post1594189371
https://www.corvetteforum.com/forums...post1563538204
Could be this isn't your problem, but I'm just spitballing here.
Old Jun 5, 2017 | 09:01 PM
StatmanRN's Avatar
StatmanRN
Its not stock, its an RPS twin carbon.
To Slave cyl sucking air?
