HVAC No Comm. Error Code
Old Jun 4, 2017 | 06:02 PM
corypeters's Avatar
corypeters
4th Gear
Default HVAC No Comm. Error Code
I just replaced my control panel with a rebuilt one. My A/C light comes on and goes off in a second. I have checked my codes and get the HVAC No Comm. error code. I have replaced the fuses to the HVAC, pulled and reinstall the panel, but same problem. Any ideas?
Old Jun 4, 2017 | 09:27 PM
FX VETTE's Avatar
FX VETTE
What was your previous HVAC doing to cause the replacement?
Old Jun 5, 2017 | 09:01 AM
corypeters's Avatar
corypeters
4th Gear
I had the dim light problem in the panel. Everything else worked. I took it out and reinstalled it yesterday and the problem was solved. Lucky I guess.
Old Jun 5, 2017 | 10:51 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If for some reason you have a similar issue in the future, get a DC Volt meter and read the VOLTAGE on the fuse for the HVAC head. Our C5 ignition switch can and will go bad and output too low of a voltage and the HVAC Head doesn't work.
All of our fuses have two small test slots on top of each fuse that you can read to ground to see if the fuse is working.
BC
To HVAC No Comm. Error Code
