2002 Z06 corvette
Old Jun 6, 2017 | 04:08 PM
ahardeds's Avatar
ahardeds
8th Gear
Default 2002 Z06 corvette
My car is over heating when I'm driving long distance could it be the headers that was put on? When I'm cruising in town it stays at a decent temp.
Old Jun 6, 2017 | 06:05 PM
dahogan's Avatar
dahogan
Enjoy while you can.
Ohio Events Coordinator
2025 Corvette of the Year Winner - Unmodified
St. Jude Donor '14 thru '26
Ask here on the forum for a better response:
https://www.corvetteforum.com/forums/c5-tech-1/
Old Jun 6, 2017 | 06:34 PM
FX VETTE's Avatar
FX VETTE
Welcome to the CF!
Old Jun 6, 2017 | 08:12 PM
Moving this to C5 Tech.
Old Jun 6, 2017 | 09:04 PM
grantv's Avatar
grantv
The fans only operate at low speeds, and you're not having low speed problems. So my guess is either the rad is clogged (potentially between) or there is something blocking air flow thru the front of the car. Are the air dams all in place?
Old Jun 7, 2017 | 07:47 AM
ahardeds's Avatar
ahardeds
8th Gear
Yes i checked all that, i was going to change the thermostat next.
Old Jun 7, 2017 | 08:52 AM
grantv's Avatar
grantv
What temperature is it showing?
Old Jun 7, 2017 | 03:44 PM
ahardeds's Avatar
ahardeds
8th Gear
long distance it will reach 275 to max red if i keep riding.. if i stop and cruise around town it will go back down to 220-230
Old Jun 9, 2017 | 10:19 AM
Rob 02's Avatar
Rob 02
The radiator gets it air from the bottom. You would be supersized at how much trash gets in the cooling fins.
Are both of your fans coming on when the engine is warm?
Otherwise your thermostat could be stuck closed.
Old Jun 9, 2017 | 12:22 PM
Rob 02's Avatar
Rob 02
^I read one of your post about the air issue. I was wondering why mine didn't do that. I do think I heard a burping sound when I took a hard right turn though.
Did you burp yours out of the throttle body steam tube?
Old Jun 9, 2017 | 01:36 PM
Rob 02's Avatar
Rob 02
Mine didn't come with a rear steam tube. I might have air in the system without knowing it because I had my temps lowered when I got my tune. Now that I think of it the air may have purged out when I replaced the coolant sending unit. My first one failed after a few weeks and it is located high enough on the head. Mine runs under 200 in Florida with A4 trans and no other trans cooler.
Old Jun 12, 2017 | 07:15 AM
ahardeds's Avatar
ahardeds
8th Gear
yes both fans are coming on. i will check for those things this afternoon
Old Jun 12, 2017 | 07:17 AM
ahardeds's Avatar
ahardeds
8th Gear
Originally Posted by 8VETTE7
Some how I'm hard pressed to think the issue is clogged radiator fins if the temp drops at cruise speed when the fans are likely running but rises at highway speeds where air flow through the radiator should provide much better cooling than the fans do at low vehicle speeds.
And it seems to me that if the T'stat was stuck closed the heating problem would constantly exist and not just at higher vehicle speeds. The fact that the temps come down when returning to lower vehicle speeds suggests that there is coolant flow occurring.
I suspect that there is air in the cooling system. I had very similar issues when there was trapped air in my cooling system. JMHO
what you think i should check for?
Old Jun 12, 2017 | 07:55 AM
vettenuts's Avatar
vettenuts
Interesting. I have never had an air in the coolant issue with my car. However, every time I have touched the coolant my car has had the front up on blocks so the car is at an angle. Wondering if you guys would have as many issue getting the air out if you were up on ramps.
Old Jun 12, 2017 | 12:27 PM
Rob 02's Avatar
Rob 02
I don't use ramps but I have to lower the back end first when taking it down from jack-stands. If you lower the front first there isn't enough clearance.
Good point vettenuts. Maybe all you need is to jack the front of the car up to burp.
Old Jun 12, 2017 | 01:55 PM
kp1's Avatar
kp1
I just turn the heat to high and run them without the cap on the fill reservoir for 10-15 minutes. Never had an issue with it.
Old Jun 13, 2017 | 08:57 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
sounds like the water pump inlet hose is collapsing under higher RPM
To 2002 Z06 corvette
