Pilot Bearing Hell.
Old Jun 8, 2017 | 12:32 PM
Moto One's Avatar
Moto One
Default Pilot Bearing Hell.
Has anyone else gone thru hell trying to remove the pilot bearing? This isn't my first rodeo doing it, and I have gone through 4 or 6 pullers, 3 diamond bits. Looking forward to getting this one out, and hope it's the last time.
Mark.
Old Jun 8, 2017 | 12:40 PM
DetroitPlac's Avatar
DetroitPlac
I rented the puller and slide hammer from O'Reilly. The puller fingers didn't quite fit, so I disassembled the puller, put the fingers in individually, and reassembled. The bearing was out in less than 5 minutes.
Old Jun 8, 2017 | 02:45 PM
TX Z06 02's Avatar
TX Z06 02
Removed mine twice. Same experience as Detroit...
Old Jun 8, 2017 | 02:48 PM
MRCoupe2002's Avatar
MRCoupe2002
Haven't done one on the current car, but I did on my '02. Took forever and the old pilot bearing was utterly destroyed in the process. Didn't break, but did damage the puller a little. It's been a few years so I don't remember how well the pull fingers fit, but it's possible that's what my problem was back then.
Old Jun 8, 2017 | 04:19 PM
Rx7Rob's Avatar
Rx7Rob
Like the others, I used the slide hammer puller and disassembled it to get it in the bearing. Some people grind the puller but I'd rather leave as much metal on it as possible.
Don't worry about tearing up the bearing. The outer lip is significantly stronger than the inner lip. I broke the inner lip, cleaned the bearings out, set the puller on the outer lip and it practically slid right out.
Old Jun 8, 2017 | 04:23 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
I used two tungsten carbide dremel bits and cut a slot to weaken it and finally that POS came out.
Dremel 9901 was the number
Old Jun 8, 2017 | 04:24 PM
nsogiba's Avatar
nsogiba
Came out in 5 minutes for me using a slide hammer.
Old Jun 8, 2017 | 06:52 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
been there
Old Jun 8, 2017 | 09:09 PM
redzg's Avatar
redzg
Does using grease as a hydraulic force not work on these?
Used to be we would pack the cavity with grease, insert a dowel, and smack it with a hammer.
Old Jun 8, 2017 | 11:11 PM
marc a's Avatar
marc a
Not a good idea with the LS1 as there is a oil plug in the end of the crank that could be pushed in.
Marc
Old Jun 9, 2017 | 09:59 AM
huesmann's Avatar
huesmann
Same, except the little fingertips on the puller I rented didn't quite have enough grab, and the fingers were a little too fat to fit inside the PB, so I did a little grinding to clearance everything. The bearing did basically have to be bashed to hell with the slide hammer, though—even if I wanted to, there's no way it could have been reused.
Old Jun 9, 2017 | 07:09 PM
redzg's Avatar
redzg
"there is a oil plug in the end of the crank that could be pushed in"
Well that's a definitive answer. Thanks for the edification!
Old Jun 10, 2017 | 01:00 PM
SVT_Z06's Avatar
SVT_Z06
Mark.
Blind hole puller worked for me. 5 minutes of slide hammering. Got this at Harbor freight. Part number 62601
Old Jun 10, 2017 | 01:03 PM
SVT_Z06's Avatar
SVT_Z06
Old Jun 10, 2017 | 05:18 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Everyone uses a slide hammer puller. Duh.
Some of them seem literally seized in there. All you can really do is cut the bearing which does two things. 1) weakens it. 2) makes you feel better by destroying it.
Old Jun 10, 2017 | 11:45 PM
Chicago1's Avatar
Chicago1
slide hammer use the chrysler one comes out like butter
Old Jun 12, 2017 | 10:29 PM
WRE's Avatar
WRE
I also used the harbor freight puller. My pilot bearing was only 2 years old, so it came out fairly easy. At first I was gripping the slide hard with my fist and slamming it against the stop. I had much better luck throwing the slide at the stop. Energy increases with the square of speed, so the faster you can get the slide moving, the more yank it'll impart
To Pilot Bearing Hell.
