Electrical problem
Old Jun 10, 2017 | 10:03 AM
Stevesvets's Avatar
Stevesvets
2nd Gear
Default Electrical problem
I just lost power to my gauges, radio, Windows, etc. I can't find any fuse problem. what do I need to check next?
Old Jun 10, 2017 | 06:56 PM
Greg_E's Avatar
Greg_E
You most likely have a serial data bus issue. Good place to start checking is the connectors in the doors for bent pins. Grab the accordian boot between the doors and A pillars and give them a shake. If the problem comes and goes you've probably found the problem.
Go to this thread and follow the advice given by Bill Curlee. If you get things working read the trouble codes and write all of them down and then clear them. take a drive and read the codes again to see what comes back.
https://www.corvetteforum.com/forums...ed-advice.html
Here is another thread where the right door control module lost communications. This is a far less common problem than the black door connector pins but there is some good information in the thread.
https://www.corvetteforum.com/forums...comm-rdcm.html
There are other threads on this subject so use the search function to find them.
