I was doing an oil change the other day and noticed some oil droplets over by the oil filter and also coming out of the bell housing. The droplets by the bell housing look to be getting blown onto the exhaust pipes behind it, which explains why I haven't seen a lot of oil spilling on my driveway.
What is the best way to determine the source of this leak? Any ideas of where to start would be helpful.
The reason I asked is because sometimes when people replace the pilot bearing they knock the plug out of the center of the crank shaft. That can be a source of an oil leak. An A4 car doesn't have a pilot bearing.
Hopefully it isn't the crank plug or rear seal. At 130K miles your rear seal shouldn't be failing and with that many miles it probably hasn't been sitting for excessively long periods of time where a rust ring would form on the shaft around the seal.
I replaced the pilot bearing using a slide hammer to pull it out, hopefully that did not mess up anything there.
What would you suggest for diagnosing the problem? I'm a DIY kind of person but don't know a ton so I like to do research and talk with a bunch of smart people on here before I get started.
First determine if the oil is coming from inside or outside of the bell housing. I have heard of using die and a black light to find a leak but personally have never done it.
The crank shaft has a hole going straight down the center with a plug on back.
How much oil are you loosing and for how long?
My car is an auto so if anyone else wants to chime in feel free.
