Lookie what I found
Old Jun 14, 2017 | 12:16 AM
surenow's Avatar
surenow
Default Lookie what I found
You guys have been saying for years check your ignition, check your ignition and well I did and look what old hack brought up.
Through the insulation and down to the wire, no wonder my car has been driving so bad.
Old Jun 14, 2017 | 01:06 AM
El original's Avatar
El original
WOW...don't look good, thanks for sharing.
Old Jun 14, 2017 | 01:22 AM
hron61's Avatar
hron61
interesting, what were the symptoms?
Old Jun 14, 2017 | 02:14 AM
surenow's Avatar
surenow
I'll let you know when I STart it up again.
Old Jun 14, 2017 | 04:55 AM
Mickeyrx70's Avatar
Mickeyrx70
Old Jun 14, 2017 | 09:58 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Old Jun 14, 2017 | 12:42 PM
v8srfun's Avatar
v8srfun
What is the wire to and did you have any problems with the car
Old Jun 14, 2017 | 12:57 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Looks like it the wire for the VATs Sensor on the end of the ignition switch. If that wire is damaged/broken, you will get a security lock out when you turn the ignition switch to ON. The security light on the IPC will NOT go out.
To Lookie what I found
