Various C5 issues - First owned corvette
Just wanted to introduce myself... I just purchased a 2001 C5 with 89k miles for $9,000. I thought and still think this was a pretty good deal but I'll let you guys decide after reading the below
That being said, the C5 that I have isn't perfect.. It's riddled with small issues left and right that I don't really know how to fix (yet) and was hoping some of you vets can point me to the right direction.
First things first.. I was driving home and was caught in the rain. Water was coming down from the T-Top weather strips AND under the dashboard. I understand that the weather strips become dated and don't seal well but I have no clue how I'm getting tons of water coming in from the passenger side dash board. It's not the AC condenser as it only happens when it rains. so there is a leak somewhere...
After the vette was caught in the rain, the driver side Front turn signal and day light no longer works (Daylight off, turn signal blinks fast and doesn't come on in the front). Any tips on where to look? I had issues with the hazard switch where the turn signal wouldn't engage at all but this is different.. no amount of punching fixes it.
I did swap out the clutch fluid using the ranger method because when I was driving in a... sporty fashion, going from second to third just wasn't feasible. No grinding.. just couldn't push it in to third. After changing the fluid, It's going in to gear as it should.. but figured I'd share.
Lastly, There are some paint chips in the rear bumper.. I've read this is the norm with the GM paints of this year but I figured I'd ask if anyone had vinyl Wrapped their vette before with this kind of paint. I had an older car that I wrapped with chipped off paint and I did more harm than good to that paint job.
Any who, sorry for the long rant.. despite all of these small issues; It's an amazing car
P.S The pop up headlights work but when you turn them off and they close, you hear an awful grinding noise as if the car is trying to close the headlight even after it's closed.
Your water leak source is from two possible areas.
The targa top leaks are probably due to the rubber seal being cracked. Most likely the rubber seal gaskets will need to be replaced. The under dash leak source could be clogged drainage "utters" that drain water from under the plastic cover at the base of the windshield. There are 3 of them and they will clog from accumulated debris. The utters are located on the firewall. Use the search function on this forum "drain utters" for information on location and how to clear them. You could also have a windshield seal problem but I'd start with the utters and move on from there.
Check post 1 at this link https://www.corvetteforum.com/forums...ak-checks.html
The C5 DRL/parking light assembly has a know problem with leaking water directly onto the bulb. The halogen bulbs give off heat that melts and cracks the top of the plastic housing directly above the bulb. You'll need to inspect those housings for cracks and either replace them, or repair the cracked area. I would recommend replacing the halogen bulb with a LED bulb to keep the new housing or replaced housing from cracking again.
Excellent link to "all things that can go wrong" drl/turn signal assembly, bulbs, sockets, and assembly removal
https://www.corvetteforum.com/forums...rning-out.html
Concur with Dub D's comments on the headlamps grinding.
Water coming out from under the dashboard sounds scary. You don't flood any of the electronics. I guess it could be the weather stripping around the windshield ?
If your BCM gets toasted, you'll have BIG troubles. They're hard to find, even on the used market. As I recall, only the 2002+ models are "readily" available--but you'll pay an arm and a leg for one if you can locate one. ALL of the C5 generation BCMs have been discontinued; I don't remember for sure, but there are definitely two versions--one for 1997-X, and X-2004 (I just don't remember what year 'X' is). If yours is ruined but you're lucky, yours will be the X-2004 version; they're still "available". If you find a new one, they're >$600 and will need dealer programming, so take care of the one you have if it's still dry. You can disassemble the metal housing to get to the circuit board and dry it out. Check for oxidation, and if it's wet, let it dry out for a few days before you reassemble the box.
There are several possible sources for leaks. Go through this "tutorial" and do everything advised in the article: https://www.corvetteforum.com/forums...ak-checks.html
If nothing else, keep your car in a sheltered area (or godforbid, tarp it) until you can be sure you don't have a leak that'll ruin the BCM.
Also, check to see if your car has an LCM5 installed. Search the forum for "LCM5" and "service column lock". This is another dreaded idiosyncrasy of the c5s.
The problems you listed may be a PITA to fix but none of them are super expensive to fix. As mentioned, get that leak fixed or keep the car under cover untill you do.
The car will be garage kept and it will not be exposed to the rain. I'll also try my best not get surprised by the rain again.
Aside from the LCM5, is there anything I should look for or do from a maintenance standpoint? The bay looks untouched and unmolested.. I'll also take a look at the tutorial that was posted.
Thanks again!
