Great car but there's ONE problem (abs)
Old Jun 23, 2017 | 08:09 AM
Spill8c5's Avatar
Spill8c5
Cruising
Default Great car but there's ONE problem (abs)
Picked up a 99 base a couple weeks ago, cars great but I have the ABS and traction light. It is the module with the "v" with active handling, so I don't want to spend 2k on a module and I called around and know you can't fix the 97-00 modules with c1243 codes, I also have the c1217 code. I've read a LOT about these issues, today I'm going to try cleaning the grounds then jacking up the rear end and inching up to 9mph to "jog" the motor hopefully. Has anyone else had these codes and fixed them in a different way? Thank you so much!
