Best Way to Drop Drivetrain?
I need a little advice on dropping the rear drivetrain; torque tube, trans, diff, and rear cradle. I will be doing a clutch swap this weekend and will most likely be doing the majority of the work by myself using jack stands. I have read several how-to's, looked at tons of pictures so I am confident I can do it.
I purchased 2 scissor trans jacks from Harbor Freight for this just like in the clutch swap write-up by Dope (hope I am crediting the correct person).
I was thinking of supporting the TT, trans, and diff assembly with one jack then dropping the rear cradle on the other and removing it. Then drop the TT/trans/diff separately using the second jack. I figured it may be easier to manipulate the separate assemblies by myself this way.
Is this a good way to do this? Anything I need to keep in mind or watch out for? Any and all suggestions are welcome.
Thanks.
I have done this 4 times on 3 cars and it is much safer and easier with helpers.
Gary
I do have a couple of neighbors that could probably give me a hand if necessary.
I know this job won't be a lot of fun, that's for sure.
Once you are ready to drop it, put the scissor jack underneath the rear cradle the long ways (wheel to wheel), position it in the middle as best you can, but don't be alarmed later when you're lowering it and the cradles moves in the jack a bit. The diff mount flexes and the cradle will flop forward or backwards a bit, once I get it on the ground I always set up some blocks to take the pressure off the mount.
Undo the 4 large subframe bolts and lower slowly watching for the brake lines and other wire connections. Careful not to lower the cradle too far before separating the TT from the engine as you can stress the dash.
Once the TT is separated I usually support it on a floor jack and then return to the back of the car and finishing lowering the cradle.
Here is a pic after it was out of my car on my most recent C5 clutch job.
Oh, I almost forgot. The HF jack is not strong enough to get the cradle up, but it does work well going down. Put your floor jacks under the spring/ball joint and lift little by little, follow with the scissor jack, goes in nice and easy. I also like a recommendation I received from here to separate the TT from the trans for reassembly, I have found it to be far easier to wrestle those two pieces back in when they are apart. Having a helper may make it more feasible to leave them together... Leave them together for the removal though!
Also, about how high do you lift the rear of the car to get enough clearance?
Just out of curiosity, what clutch are you running? Thanks again.
I usually use some 4x4 blocks in addition to my full jack heigh, probably 2 1/2-3ft. Get it as high as you can safely go. There is no such thing as too high when doing this.
Drive train supported, cradle removed. Block of wood on forward cradle is cupped to support torque tube.
How heavy is the cradle assembly? Can it be taken off the jack once it is lowered out of the car by 1 person?
Here's a thread I did for a whole drivetrain rebuild with plenty of pics:
https://www.corvetteforum.com/forums...dies-pics.html
Rear cradle assembly removed. Rotors and caliper brackets removed helped a lot.
TT/Trans/diff dropped
Old clutch removed.
Stock LS6 clutch. Still held good but lots of hot spots.
New LS7 Pressure Plate.
LS7 Flywheel
LS7 clutch and flywheel installed. You can see one of the broken exhaust flange bolts on in the lower left corner.
Drive train and rear cradle back in.
A few things that I have learned while doing this:
1. Harbor Freight scissor jacks are kind of crappy. They work okay to support the cradle and TT/trans/diff and to move them around but are terrible for lifting. If I ever need to do this again, I will get a hydraulic trans jack.
2. Before you unbolt the TT from the bell housing, measure the angle of the torque tube and measure the front and rear of the drivetrain and record these for re-assembly. Makes re-assembly way quicker/easier.
3. Get a blind hole bearing puller for the pilot bearing and use heat on the crank where the bearing goes. It will make it much easier to get the old bearing out.
4. Make sure the wiring harness on top of the bellhousing doesn't get pinched between the TT and bellhousing during assembly. At first I couldn't figure out why they wouldn't go together but it was the wiring harness getting caught. It is easy to overlook as the harness is black and easy to miss it.
5. If installing an LS7 clutch and flywheel, hammer the Pressure Plate locating dowels until they bottom out in the flywheel. Otherwise, there isn't enough room to get the disc and PP installed.
5. It's not too difficult of a job, just time consuming. I did it by myself on jack stands in the parking lot of my apartment. Total time was about 15 solids hours of work. 13 hours if I don't include the time it took to remove 2 broken exhaust flange bolts.
6. You should measure if you need to shim the slave. I used a stock LS7 flywheel and clutch and a GM slave and it needed a 0.113 shim to be in spec. Don't just assume yours is okay.
Another thing. I had a lot of curious people stop by while I was working and either ask me questions about what I was doing or to ask advice about things they need to fix with their cars (which I don't mind at all). It was surprising but also kind of cool.
