Corvette Camaro Tuner in Tampa
Former Vendor
St. Jude Donor '12
Check out my website -->> www.TampaTuning.com
Tampa Tuning is the home for street performance tuning for $295 on Corvettes and Camaros at the stock to bolt ons level. My street tuning process takes several hours to complete. It the best way to collect scanner data for low end drivability and WOT under actual load and airflow of the vehicle.
My HP Tuners interface has unlimited credits for LS1, LS2, LS3, LS6, LS7, LSA, LS9, L99 engines
C7, Gen6 Camaros, and trucks are $100 more.
Great modification for the buck!
Instagram : TampaTuning
OUR TOTAL STREET PERFORMANCE TUNING PACKAGE FOR GM LS1-7 VEHICLES IS $295.00 WITH TRANSMISSION PACKAGE INCLUDES:
Read and reprogram your PCMs settings and perform real time scanning diagnostics for the best results
Increase power enrichment rate mode
Examine and change timing tables for additional horsepower & torque gain
Optimize your vehicles Air and Fuel Ratio monitored by the NGK/ AFX wideband unit
Reduction of intake air temperature table (heat soak)
Desired rev limiter adjustments
Park, neutral, and in- gear idle adjustments with and without A/C active
Adjust power enrichment delay to immediate
Engine torque management system reduced
Transmission torque management system reduced
Transmission shift points enhanced
Transmission shift times reduced
Transmission shift pressure firmness enhanced if needed
Skip shift deleted (CAGs 1st to 4th )
Fuel injector rescaling for aftermarket injectors if needed
Cooling fan activation temperature and percentage of cooling recalculated
Perform speedometer recalibration for rear gear ratio and tire size change
Turn off check engine light and remove trouble codes
Neutralize rear oxygen sensors if needed
Phil
Phil
Former Vendor
St. Jude Donor '12
Corvette Camaro Truck Tuner in Tampa
Thank you for allowing me to calibrate your Corvette. I hope each of you enjoy the three day weekend.
Phil
Tuning@TampaTuning.com
www.TampaTuning.com
Phil
www.TampaTuning.com
Former Vendor
St. Jude Donor '12
Good luck Florida friends with Irma.
Reach us at : Tuning@TampaTuning.com
Check out our Website: www.TampaTuning.com
Phil- Owner of Tampa Tuning.
Former Vendor
St. Jude Donor '12
Corvette Camaro Truck tuner in Tampa
Phil
Phil
www.TampaTuning.com
Former Vendor
St. Jude Donor '12
813-727-8720
813-727-8720
Former Vendor
St. Jude Donor '12
Cool weather equals a quicker car. Lets throw some bolt ons on it and a tune, and make the car more fun
813-727-8720
813-727-8720
Former Vendor
St. Jude Donor '12
Corvette Camaro Truck Tuner in Tampa Orlando
Home of the $295 Calibration with HP Tuners and wideband for stock to bolt ons Corvettes and Camaros to be street race tuned.
The process takes about three hours. I fix a lot of local work because they do 3 pulls on the dyno and your done. That's not how you calibrate a Corvette. Tampa Tuning's in-depth computer process includes low end parking lot driving, cruising spirited driving and WOT.
Tampa Tuning wants to make sure we cover ALL the ranges your car performs in. Price is $295 for 1997 to 2013 Corvettes. Price is $395 for 2014 to 2016.
Cam'd and Supercharged Corvettes, Email me with build for pricing.
<<<<<<>>>>>> Check out our Website: www.TampaTuning.com
813-727-8720
813-727-8720
