Fuel filter removal
Old Jul 3, 2017 | 04:57 PM
av8or's Avatar
av8or
Default Fuel filter removal
In the process of changing my fuel filter.... can't get the filter off of the hard tube (output) side. I assume the tube is flared, and the filter pulls off with a yank? (Looking at the new filter, appears four little "prongs" hold it on once over the flare?)
My new filter did not come with any kind of rubber washer or gasket... should it have?
thanks
Old Jul 3, 2017 | 05:26 PM
frodo84's Avatar
frodo84
Uneducated autodidact
You need a special fuel line disconnect tool to release the factory ends where they "snap" over the bulge in the metal lines. Not expensive, you can buy the tool at any parts store.
Old Jul 3, 2017 | 05:27 PM
feeder82's Avatar
feeder82
no it doesn't yank off you need a fuel line tool, you push in on the line, push the tool into the filter and it comes apart
Old Jul 3, 2017 | 05:28 PM
feeder82's Avatar
feeder82
haa guess i type too slow
Old Jul 3, 2017 | 05:33 PM
av8or's Avatar
av8or
Thanks. Now to get to the parts store before holiday closing!
Old Jul 3, 2017 | 06:22 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
It's been a couple of years since I've changed the fuel filter, BUT.....I seem to recall that the filter has the plastic clips that you squeeze in (a pain in the azz, BTW), to release the filter from the lines. The release tool, is used where the fuel lines connect to the fuel rail, under the hood.
Old Jul 3, 2017 | 06:33 PM
feeder82's Avatar
feeder82
the in side has the clips, the out line needs the tool
Old Jul 3, 2017 | 08:20 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I agree with FEEDER & frodo84. Make sure ALL fuel line presure is released at the shrader valve on the fuel rail. PUSH the filter IN onto the hard line , insert the release tool while you pres IN on the filter, pull the filter OFF once the tool is inserted.
New filter just presses bback on the line. CAREFUL! DO NOT BEND, BREAK the plactic line!!!!!!!!!!!!!!!!!!!
BC
Old Jul 4, 2017 | 07:54 AM
leadfoot4's Avatar
leadfoot4
OK. Like I said, it's been a couple of years.............
Old Jul 4, 2017 | 11:52 AM
av8or's Avatar
av8or
Thank guys... got it done!
My car has 30,000 miles, this is the first gas filter change. Saw posts from others with similar mileage that mentioned nasty, dirty gas dripping from the filter after removal. The gas that drained from my filter looked normal... clean. Maybe a steady diet of nothing but top-tier gas pays off?
Old Jul 4, 2017 | 06:25 PM
leadfoot4's Avatar
leadfoot4
I would say so. I've recently read, on a couple of car discussion websites, about "dirty" fuel draining from the inlet side of the filter, during a change. IMHO, that's the fault of the pump that's filling the tank, not the car (unless, of course, you have an older car, with a rusty steel gas tank).
Old Jul 5, 2017 | 07:45 PM
dbgoodwin's Avatar
dbgoodwin
The best tool for the job is a small plastic funnel. Cut the tip off and then cut through one side of the tip, and it makes a better tool than anything you can buy at the parts stores. Been using mine for years now, after I failed to get the original filter off my car using the parts store tool.
Old Jul 5, 2017 | 07:53 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
LOL!!! I used the small RED (FME) Cap that came with the new fuel filter. The cap close off the opening of the new filter to prevent dirt from entering the new filter. I cut the closed end off the cap, split the barrel part of the cap in a spiral and used it to release the the filter. Worked like a champ!
Bill
Old Jul 5, 2017 | 09:12 PM
av8or's Avatar
av8or
NOW you tell me . I'm now the owner of six new "fuel line disconnect" devices, 5/16 to 7/8.... all but one of which I probably will never use. $9 at Advanced Auto.
Never thought to use the red cap! Live and learn.
Old Jul 6, 2017 | 08:49 AM
leadfoot4's Avatar
leadfoot4
Me neither, and I've been changing that type of filter for a number of years. I, too, have the $9 selection of release tools, of which I've used only two of them.....
Old Jul 12, 2017 | 04:10 AM
Sam Handwich's Avatar
Sam Handwich
Just changed my fuel filter at 43,000 miles. The gas that came out was clean. But I had very noticeable gas smell after fill-up so I figured it was time.
Old Jul 12, 2017 | 08:14 PM
jackthelad's Avatar
jackthelad
Changed mine when I noticed strange noises from the area of the fuel tank on the driver side. Those "release" tools are mostly useless - a pair of pliers did the job, and the new filter came with new fittings. No issues since - maybe 4 years ago.
Just glad I had a early build car with an inline filter and not one in the tank.
To Fuel filter removal
