Is the odometer data stored in the BCM?
Old Oct 1, 2002 | 06:32 PM
Bugster57's Avatar
Bugster57
Default Is the odometer data stored in the BCM?
I believe this is true, just wanted to confirm for a friend.
The BCM was replaced in his daughters car and later he realized the mileage had gained about 35K. Seems the BCM was replaced with a used unit.
How is the correct data reprogramed?
Old Oct 2, 2002 | 04:15 AM
Mike Schriber's Avatar
Mike Schriber
Default Re: Is the odometer data stored in the BCM? (Bugster57)
Hmmmm... if I'm not mistaken, the odometer data is stored in the IPC (instrument panel cluster), not the BCM.
Mike :flag
Old Oct 2, 2002 | 09:31 AM
NJVetteGuy's Avatar
NJVetteGuy
Default Re: Is the odometer data stored in the BCM? (Mike Schriber)
On most Chrysler products, the instrument cluster only displays the mileage stored in the BCM.
Old Oct 3, 2002 | 03:26 AM
Mike Schriber
Default Re: Is the odometer data stored in the BCM? (NJVetteGuy)
Chrysler? Did I miss something?
Mike :flag
Old Oct 3, 2002 | 01:03 PM
QwikSilvr's Avatar
QwikSilvr
Mike :flag
Mike is correct. A friend of mine has a programmer and the procedure to change mileage on these cars is to take the IPC out and program it.
To Is the odometer data stored in the BCM?
