2002 Z06 Oil Temp
If you're running hot, step 1, blow out the radiator core with compressed air, through the fins, back to front. That can drop your temps 10, 15, 20... hell, 30, 40, 50 degrees F, depending on how dirty it is.
The low speed cooling fan is commanded on when the coolant temperature reaches 108°C (226°F). It is turned off if the coolant temperature lowers to 104°C (219°F). The high speed cooling fan is commanded on when the coolant temperature reaches 113°C (235°F). It is turned off if the coolant temperature lowers to 108°C (226°F). When the A/C is on and the coolant temperature reaches 85°C (185°F), the low speed cooling fan will be turned on at vehicle speeds less than 56 kPh (35 mph).
Normal driving with driving speed that flows sufficient air across the radiator with the AC off, the coolant temperature with a factory thermostat is 190°F, The fans will be off. The factory setting will not let the first cooling fan come on until the coolant reaches 226°F.
The low speed cooling fan is commanded on when the coolant temperature reaches 226°F. It is turned off if the coolant temperature lowers to 219°F. The high speed cooling fan is commanded on when the coolant temperature reaches 235°F. It is turned off if the coolant temperature lowers to 226°F. When the A/C is on and the coolant temperature reaches 185°F, the low speed cooling fan will be turned on at vehicle speeds less than 35 mph.
The low speed cooling fans are controlled by the PCM based on the following inputs:
The A/C system
The Engine Coolant Temperature (ECT) sensor
The Vehicle Speed Sensor (VSS)
The PCM will turn the low speed cooling fans ON when any of the following conditions exist at idle:
Certain PCM Diagnostic Trouble Codes (DTCs) are set
ECT above 104°C (219°F) will enable low speed fans
A/C head pressure above 1510 kPa (219 psi)
Once the low speed fans are turned ON by Engine Coolant Temperature, the PCM will turn the fans OFF when that temperature has dropped about 6°C (11°F) . If the low speed cooling fans are turned ON by high A/C head pressure, the PCM will turn the fans OFF when the pressure has dropped to 1034 kPa (150 psi). The minimum ON time for the low speed cooling fans is 50 seconds.
When engine speed is above 3500 RPM for 12 seconds and the engine oil temperature is above 127°C (261 °F), the low speed cooling fans will be turned ON.
HIGH SPEED COOLING FANS
The High Speed Cooling Fans are controlled by the PCM based on the following inputs:
The A/C system
The PCM will enable high speed cooling for both fans when any of the following conditions exist:
Certain PCM Diagnostic Trouble Codes (DTCs) set
ECT above 109°C (228°F)
A/C head pressure above 1551 kPa (225 psi)
Once the high speed cooling fans are turned ON by the Engine coolant temperature, the PCM will turn the fans OFF when that temperature has dropped about 6°C (11°F) . If the high speed cooling fans are turned ON by high A/C head pressure, the PCM will turn the fans OFF when the pressure has dropped to 1241 kPa (180 psi). The minimum ON time for the high speed cooling fans is 26 seconds.
When driving/ cruising the engine should run close to what the thermostat is rated.
Oil temperatures are usually 20dgF higher than the coolant temps but change more slowly than coolant temps.
Try the long uphill stretch going west to east in Death Valley when it is 115 to 120 deg F out.
This is probably at or close to the worst case design cooling condition.
While my 2002 MN6 did not overheat, it wasn't very far below redline.
