From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
Originally Posted by Pounder
but then my info was fact with the same silver looking fluid !!!!!!!!!!
Looking at the oil is not a good way to tell. My transmission and rear end both had me convinced they were shot and the oil analysis on both of them came back with flying colors. I would be more inclined to take a powerful magnet through the oil for a while and see if it comes up with anything on it. If it does, then that's different. But for general maintenance I've become a firm believer in Blackstone labs.
don't disagree, but as far as a magnet, aluminum won't show !!! all I know is when ours came out like silver paint and having plus 100 k on it and was changing trans, I was not going to overlook the diff !!!!!
I've changed a lot of oil in my days and I've never seen anything like the stuff that just came out of my C6. It's got to be something about the synthetic oils. I have a friend with a garage 3 doors from my work and we put it up on his lift and I took samples out. Both the transmission and rear end oils looked like you were mixing metallic paint. My heart just sank thinking, OMG , this is going to be $10,000. The trans and diff were out on the floor before the emails came with the oil analysis.
I don't know what the stuff is, but BMW and GM used it, my guess is a additive that helps cut down wear or helps resist wear under pressure.
I paniced also and nearly bought a new differential getting prepared for the fix when the oil sample test came back perfect I was in shock.
That was about 25,000 miles ago and it still runs quiet and happy on the oil I installed so I think the Oil Test was accurate.
