Problems in the DIC
Old Jul 9, 2017 | 11:13 PM
Sam Handwich's Avatar
Sam Handwich
Default Problems in the DIC
Awww nutz - just realized I did not pull codes.
Anyway, here are the weird things I have seen:
1) Changed my oil and did the reset on the reminder, but the oil reset would not "hold". It looked like it cleared out, but on later toggle thru of the gauges it would be back at 8%.
2) Changed the fuel filter after I first disconnected battery. No leaks and the car started like normal. But on test drive a few DIC readings were off. Actually, the oil change was at 8% again, but it accepted the reset and now reads 100%. However, 3 of the tire PSI readings are blank.
Looking for ideas, etc. (and will pull codes sometime tomorrow .....
Old Jul 10, 2017 | 09:45 AM
coia96vette's Avatar
coia96vette
If you can not reset the olm through the dic, try turning on the key but do not start the car. Push the gas pedal to the floor three times and turn key off. This is a standard method for GM cars.
Old Jul 11, 2017 | 02:13 PM
Sam Handwich
Originally Posted by 8VETTE7
Post the code related to the B0 - RFA
Likely you have a NO COMM or there are sensors that are no longer reporting............ CODES!!!!!!
The only code I am getting is at BO - RFA code C2110H.
And the problem with the tire pressure readings being blank? Back to normal. Fixed itself?, I guess
To Problems in the DIC
