How do O2 Simulators Work?
Old Oct 2, 2002 | 12:41 AM
Mark VerMurlen's Avatar
Mark VerMurlen
Default How do O2 Simulators Work?
I've been thinking about getting headers for my car and I notice that O2 simulators are being included with many FLP Header packages. So I wonder how the O2 simulators work? Its my understanding that the computer reads the real O2 sensor and adjusts the air/fuel ratio depending on the reading. So what does an O2 simulator do to the computer's attempts to adjust A/F ratios? I would think it would prevent the computer from fine tuning the A/F ratio for better performance. Thoughts?
- Mark
Old Oct 2, 2002 | 09:55 AM
vstella's Avatar
vstella
Default Re: How do O2 Simulators Work? (Mark VerMurlen)
The 02 sims do exactly that..They simulate the feedback so the PCM does not code..No problems when adding headers..:D
Old Oct 2, 2002 | 10:18 AM
Mark VerMurlen
Default Re: How do O2 Simulators Work? (vstella)
Ok, so the computer can no longer adjust A/F ratios because is being tricked. So what down side does this have? I would guess that it can not adjust for any modifications to the engine, so you should have a custom programming done any time to make a change. I would guess that it can not adjust for altitude changes because it can't sense that the O2 level is changing. I assume its a given that emissions would increase. I would also guess that fuel economy is decreased. I would also be afraid that general drivability would suffer. Is any of this true?
- Mark
Old Oct 2, 2002 | 10:31 AM
Chris@SD's Avatar
Chris@SD
Rear O2 sensors only tell the computer whether the cats are functioning or not. AF is determined by the front O2 sensors only. :)
Good Luck,
Old Oct 2, 2002 | 10:36 AM
Mark VerMurlen
Default Re: How do O2 Simulators Work? (Chris@SpeedDemon)
Ahhh... Then there shouldn't be any downside at all! Thanks for the clarification.
- Mark
Old Oct 2, 2002 | 12:29 PM
jmX's Avatar
jmX
Good Luck,
What he said. You have 4 O2 sensors stock, the simms just go on the rear 2 which aren't used for A/F ratio adjustments by the PCM.
Old Oct 2, 2002 | 01:29 PM
C5Longhorn's Avatar
C5Longhorn
Default Re: How do O2 Simulators Work? (jmX)
Plus when you remove all the wiring, you'll save some weight :D
Old Oct 2, 2002 | 01:36 PM
jmX's Avatar
jmX
Default Re: How do O2 Simulators Work? (rschiltz)
No wiring is removed. You unplug your o2 sensor, and plug in a simm. Thats it.
To How do O2 Simulators Work?
