Torque Tube From Engine
Old Jul 18, 2017 | 02:58 PM
ClevelandTim's Avatar
ClevelandTim
Default Torque Tube From Engine
I'm in the process of replacing a bad flex plate from my 2000 auto. I've got the rear cradle free of the frame, the collar that hold the front spline of the TT to the engine has been unbolted. My problem is I can only get about 1 inch of separation between the two. Any tricks or tips to get both pieces apart so I can get to the flex plate?
Thanks,
Tim
Old Jul 18, 2017 | 04:01 PM
HPS MASTER TECH's Avatar
HPS MASTER TECH
you gotta pull the tube away from the bell housing. or remove your trans and pull the drive shaft back
Old Jul 18, 2017 | 05:05 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
https://www.corvetteforum.com/forums...oval-help.html
Old Jul 18, 2017 | 05:06 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Tim, Is the transmission shift cable still attached? It could hold things up.
Are the wiring harnesses free from their clamps/brackets?
I've found the easiest way requires unbolting the trans from the TT and removing the trans/diff as one unit. Then removing the torque tube.
Good luck with your project!
Old Jul 18, 2017 | 05:08 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
A transmission jack is a life saver on a clutch swap, and I would assume pulling an A4 as well.
Old Jul 19, 2017 | 12:21 AM
ClevelandTim
All out today. Thanks guys. Used some ratchet straps to pull the TT & cradle assembly away from the engine. On to replacing the flex plate.
To Torque Tube From Engine
