Went for a ride tonight when I got home I noticed a little coolant around where the top radiator hose goes into the radiator. The plastic tank right on the top has a small crack can this be fixed or should I start thinking new radiator. If you find a good radiator shop can they replace the plastic tanks?
My 2001 radiator did this 2 months ago. I decided to replace with new. Rock auto has a variety of repalcement radiators. I went with the AC Delco stock replacement a little over 200.00 dollars.
I think they can replace the plastic tanks, but the original lasted 16 years and that is why I just went with new. If your car is a 6 speed the price is cheaper than the one for my A4.
I had the same problem,a leak in the upper left plastic. I replaced with a stock part since it is part of a system, and is light. I didn't want to change the original design, since the aftermarket stuff weighs more and would create a different operating result.
While most things can be fixed, plastic in a high heat and pressure situation would test my abilities for plastic repair, if I had a bunch, which I don't . PLastic can be welded, bonded , or patched mechanically. It also gets old and brittle. My temps went down about 5 degrees with the new part. What can I say, cleanliness is next to godliness.
You have to go to all of the work to get the radiator out just to take it to a radiator shop (I wouldn't take the car and let them do the removal). Since that is done and a repair is going to run you at least $100 why not pop for new?
If you want something better then you could go for an aluminum racing radiator like a DeWitts or Ron Davis unit and not worry about oil or coolant temps again. However, that would probably cost you at least 2.5 times as much as a stock replacement from one of the low cost suppliers of GM parts. If you track the car go for the racing radiator if you don't go for the stock replacement.
