front lowering bolt removeal
Old Jul 23, 2017 | 10:42 AM
latenightlarry's Avatar
latenightlarry
Default front lowering bolt removeal
morning everyone wondering if there is an easy way to remove the front lowering bolt so i can replace it with a thinner pad. any response willhelp. thanks in advance, Larry
Old Jul 26, 2017 | 12:37 PM
nsogiba's Avatar
nsogiba
Just remove the spring, that's the easiest way to get those pesky bolts out.
Beware that you may encounter some clunking sounds during low speed parking lot steering maneuvers with no bolts up front. I had to install some durable rubber pads (3/8 thickness) to make the sound go away.
