99 fuel hat
Old Jul 23, 2017 | 03:28 PM
romandian's Avatar
romandian
Default 99 fuel hat
left tank. what are the three connections? black (bottom) is pump out, im pretty sure, it goes to the t for siphone pump. now blue and green. one should be the return from right tank. the other evap system perhaps? thanks.
Old Jul 23, 2017 | 04:17 PM
StingrayRebel's Avatar
StingrayRebel
I believe the other one is to transfer fuel from the passenger tank siphon pump to the driver side tank
Old Jul 24, 2017 | 12:07 AM
romandian's Avatar
romandian
yes, but which one? one should also be the return from the regulator. is the evap system connected somewhere else? i was considering using the line as return.
Old Jul 24, 2017 | 12:23 AM
StingrayRebel
if you're looking straight at the hat I believe it is the one on the far left, center is the main return, and far right is the feed to the pump
To 99 fuel hat
